Having audio dropouts on an Elemental rip.
Audio is True HD Atmos on my Vero 4k+.
Seems to drop out on loud parts.
Have my Vero on passthrough mode for audio, to Yamaha RX-A880
General
Unique ID : 141593188235141779913126257693917953925 (0x6A85DB2A4F10BAA52895BB5435A7BF85)
Complete name : E:\Data\Movies\Elemental (2023)\Elemental (2023) - [Remux-2160p][HEVC][TRUEHD ATMOS 7.1][EN][FraMeSToR].mkv
Format : Matroska
Format version : Version 4
File size : 32.4 GiB
Duration : 1 h 41 min
Overall bit rate : 45.7 Mb/s
Frame rate : 23.976 FPS
Movie name : Elemental (2023) 4K
Encoded date : 2023-10-28 15:00:10 UTC
Writing application : mkvmerge v79.0 ('Funeral Pyres') 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
IMDB : tt15789038
TMDB : movie/976573
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 40.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.205
Stream size : 28.8 GiB (89%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 888 kb/s
Maximum bit rate : 5 475 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 2.76 GiB (9%)
Title : TrueHD Atmos 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 13
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Compression mode : Lossy
Stream size : 464 MiB (1%)
Title : AC-3 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 320 kb/s
Channel(s) : 2 channels
Stream size : 232 MiB (1%)
Title : Commentary by Peter Sohn/Sanjay Bakshi/Mike Venturini/Gwendelyn Enderoglu
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 32 min
Bit rate : 51 b/s
Frame rate : 0.220 FPS
Count of elements : 1224
Stream size : 35.3 KiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 40 min
Bit rate : 51.3 kb/s
Frame rate : 0.648 FPS
Count of elements : 3906
Stream size : 36.8 MiB (0%)
Title : English (SDH)
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 1 h 39 min
Bit rate : 40 b/s
Frame rate : 0.170 FPS
Count of elements : 1016
Stream size : 29.4 KiB (0%)
Title : Dutch
Language : Dutch
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Bit rate : 35.8 kb/s
Frame rate : 0.418 FPS
Count of elements : 2542
Stream size : 25.9 MiB (0%)
Title : French (Canadian)
Language : French (CA)
Default : No
Forced : No
Text #5
Format : PGS
Muxing mode : zlib
Bit rate : 33.7 kb/s
Frame rate : 0.424 FPS
Count of elements : 2556
Stream size : 24.2 MiB (0%)
Title : Spanish (Latin American)
Language : Spanish (Latin America)
Default : No
Forced : No
Text #6
Format : PGS
Muxing mode : zlib
Bit rate : 73.9 kb/s
Frame rate : 0.612 FPS
Count of elements : 3640
Stream size : 52.4 MiB (0%)
Title : English (Commentary)
Language : English
Default : No
Forced : No
Text #7
Format : PGS
Muxing mode : zlib
Bit rate : 65.4 kb/s
Frame rate : 0.584 FPS
Count of elements : 3504
Stream size : 46.8 MiB (0%)
Title : French (Commentary)
Default : No
Forced : No
Text #8
Format : PGS
Muxing mode : zlib
Bit rate : 60.5 kb/s
Frame rate : 0.538 FPS
Count of elements : 3198
Stream size : 42.9 MiB (0%)
Title : Spanish (Commentary)
Default : No
Forced : No
Menu
00:00:00.000 : en:Parents' Story
00:08:16.162 : en:Fireplace
00:11:11.170 : en:Delivery
00:14:24.572 : en:Ember's Fault
00:18:14.385 : en:Stop Wade
00:21:24.741 : en:Fern Burned
00:22:54.915 : en:Fire Land Flashback
00:25:24.231 : en:Return To City Hall
00:26:11.194 : en:Air Stadium
00:31:29.220 : en:Swept Away
00:32:33.368 : en:Hot Air Balloon
00:35:54.235 : en:Culvert
00:38:32.018 : en:Connection Montage
00:42:43.185 : en:Watered Down
00:47:12.120 : en:Candlelight
00:51:35.634 : en:Water Dinner
00:58:51.527 : en:Cinder Finds Out
01:02:46.262 : en:Bernie's Gift
01:05:08.571 : en:Bubble Date
01:09:46.015 : en:First Touch
01:13:47.589 : en:Grand Reopening
01:18:00.592 : en:Dark Ember
01:19:22.257 : en:Fire Town Flood
01:24:23.266 : en:After The Flood
01:28:28.511 : en:The Bow
01:31:37.825 : en:End Credits
01:33:51.875 : en:Credit Crawl
