Atmos issues
Finally found some time to re-rip the UHD of Toy Story 2. Getting a LOT of av sync messages, using the latest MakeMKV version 1.16.7. I can’t remember what it was when I ripped Toy Story 2 before…, since it’s been a long time…
Anyway, verdict is… marginal improvement. It still glitches at 50:49, albeit it’s very subtle, and also at 51:34 there’s a big sound pause/glitch. Oh well. I give up.
V synchronization issues were found in file ‘/Volumes/500GB Temp Drive/Toy Story 2_t01.mkv’ (title #2)
AV sync issue in stream 1 at 0:00:00 with duration of 0.666ms : encountered overlapping frame, audio skew is +0.666ms
AV sync issue in stream 2 at 0:00:00 with duration of 0.666ms : encountered overlapping frame, audio skew is +0.666ms
AV sync issue in stream 2 at 0:00:45.336 with duration of 6.486ms : encountered overlapping frame, audio skew is +7.152ms
AV sync issue in stream 3 at 0:00:45.336 with duration of 7.041ms : encountered overlapping frame, audio skew is +7.041ms
AV sync issue in stream 2 at 0:01:38.181 with duration of 19.83ms : encountered overlapping frame, audio skew is +26.983ms
AV sync issue in stream 3 at 0:01:38.181 with duration of 19.541ms : encountered overlapping frame, audio skew is +26.583ms
AV sync issue in stream 2 at 0:03:41.136 with duration of 20.166ms : encountered overlapping frame, audio skew is +47.15ms
AV sync issue in stream 2 at 0:03:41.184 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +15.15ms
AV sync issue in stream 3 at 0:03:41.137 with duration of 19.833ms : encountered overlapping frame, audio skew is +46.416ms
AV sync issue in stream 3 at 0:03:41.184 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +14.416ms
AV sync issue in stream 2 at 0:04:25.598 with duration of 18.35ms : encountered overlapping frame, audio skew is +33.5ms
AV sync issue in stream 2 at 0:04:25.632 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +1.5ms
AV sync issue in stream 3 at 0:04:25.598 with duration of 18.916ms : encountered overlapping frame, audio skew is +33.333ms
AV sync issue in stream 3 at 0:04:25.632 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +1.333ms
AV sync issue in stream 2 at 0:18:11.047 with duration of 22.819ms : encountered overlapping frame, audio skew is +24.319ms
AV sync issue in stream 3 at 0:18:11.048 with duration of 22.375ms : encountered overlapping frame, audio skew is +23.708ms
AV sync issue in stream 2 at 0:18:37.907 with duration of 20ms : encountered overlapping frame, audio skew is +44.319ms
AV sync issue in stream 2 at 0:18:37.952 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.319ms
AV sync issue in stream 3 at 0:18:37.908 with duration of 19.833ms : encountered overlapping frame, audio skew is +43.541ms
AV sync issue in stream 3 at 0:18:37.952 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.541ms
AV sync issue in stream 2 at 0:32:33.492 with duration of 30.994ms : encountered overlapping frame, audio skew is +43.313ms
AV sync issue in stream 2 at 0:32:33.536 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.313ms
AV sync issue in stream 3 at 0:32:33.493 with duration of 31.25ms : encountered overlapping frame, audio skew is +42.791ms
AV sync issue in stream 3 at 0:32:33.536 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +10.791ms
AV sync issue in stream 2 at 0:33:06.609 with duration of 3.338ms : encountered overlapping frame, audio skew is +14.652ms
AV sync issue in stream 3 at 0:33:06.609 with duration of 3.583ms : encountered overlapping frame, audio skew is +14.375ms
AV sync issue in stream 2 at 0:40:05.486 with duration of 3.33ms : encountered overlapping frame, audio skew is +17.983ms
AV sync issue in stream 3 at 0:40:05.486 with duration of 3.208ms : encountered overlapping frame, audio skew is +17.583ms
AV sync issue in stream 2 at 0:40:45.776 with duration of 30.016ms : encountered overlapping frame, audio skew is +48ms
AV sync issue in stream 2 at 0:40:45.824 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +16ms
AV sync issue in stream 3 at 0:40:45.776 with duration of 29.75ms : encountered overlapping frame, audio skew is +47.333ms
AV sync issue in stream 3 at 0:40:45.824 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +15.333ms
AV sync issue in stream 2 at 0:43:01.161 with duration of 6.15ms : encountered overlapping frame, audio skew is +22.15ms
AV sync issue in stream 3 at 0:43:01.161 with duration of 6.75ms : encountered overlapping frame, audio skew is +22.083ms
AV sync issue in stream 2 at 0:43:30.316 with duration of 29.83ms : encountered overlapping frame, audio skew is +51.98ms
AV sync issue in stream 2 at 0:43:30.368 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +19.98ms
AV sync issue in stream 3 at 0:43:30.316 with duration of 29.875ms : encountered overlapping frame, audio skew is +51.958ms
AV sync issue in stream 3 at 0:43:30.368 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +19.958ms
AV sync issue in stream 2 at 0:50:48.711 with duration of 4.186ms : encountered overlapping frame, audio skew is +24.166ms
AV sync issue in stream 3 at 0:50:48.712 with duration of 3.708ms : encountered overlapping frame, audio skew is +23.666ms
AV sync issue in stream 2 at 0:51:34.132 with duration of 19.147ms : encountered overlapping frame, audio skew is +43.313ms
AV sync issue in stream 2 at 0:51:34.176 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.313ms
AV sync issue in stream 3 at 0:51:34.132 with duration of 19.625ms : encountered overlapping frame, audio skew is +43.291ms
AV sync issue in stream 3 at 0:51:34.176 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.291ms
AV sync issue in stream 2 at 1:25:09.479 with duration of 13.333ms : encountered overlapping frame, audio skew is +24.647ms
AV sync issue in stream 3 at 1:25:09.479 with duration of 13.333ms : encountered overlapping frame, audio skew is +24.625ms
AV sync issue in stream 2 at 1:25:48.810 with duration of 29.186ms : encountered overlapping frame, audio skew is +53.833ms
AV sync issue in stream 2 at 1:25:48.864 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +21.833ms
AV sync issue in stream 3 at 1:25:48.810 with duration of 29.041ms : encountered overlapping frame, audio skew is +53.666ms
AV sync issue in stream 3 at 1:25:48.864 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +21.666ms
AV sync issue in stream 2 at 1:32:24.371 with duration of 22.333ms : encountered overlapping frame, audio skew is +44.166ms
AV sync issue in stream 2 at 1:32:24.416 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.166ms
AV sync issue in stream 3 at 1:32:24.372 with duration of 22.166ms : encountered overlapping frame, audio skew is +43.833ms
AV sync issue in stream 3 at 1:32:24.416 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.833ms
AV sync issue in stream 5 at 0:00:00 : Forced subtitles track #5 turned out to be empty and was removed from output file
AV sync issue in stream 7 at 0:00:00 : Forced subtitles track #7 turned out to be empty and was removed from output file
Interesting, but I don’t hear those glitches. What Make/Model of AVR do you have? I assume you’ve made sure it’s got all the latest updates. For the record, I have a Yamaha RX-A660.
Yes it’s a Sony HT-ST5000 hooked up to my CX LG OLED. I also just checked it downstairs in my movie room with a second Vero 4K+. JVC RS790 projector and a Denon 4300H with a proper Atmos setup. It does not glitch (or if it does it’s so very slight that I can’t say for sure it is) but the 51:34 glitch/blip is still present, and obvious. So, we definitely improved on my prior/early Remux in terms of the 50:49. The 51:34 is still the same blip as my earlier remux.
Did you test at 51:34?
Just verified, no glitch at 51:34. I wonder if we have different editions, at 51:34 the movie is very quite, just singing. Can you get a screen shot of where you hear the glitch so I can be sure I’m at the same part of the movie?
EDIT: I guess we do have the same version as your MakeMKV log info seems to match exactly with mine. But a screen shot wouldn’t hurt.
EDIT2: When you are selecting the audio to rip, are you selecting both the TrueHD Surround 7.1 and the linked DD Surround 5.1 track, or are you just selecting the 7.1 track?
I have both tracks selected. Let me grab a screenshot…
Yep, that’s the exact same spot. And no glitch for me with my Yamaha.
I’m out of ideas to try. My guess is that some AVRs are more susceptible to Atmos problems. With my Yamaha I’ve only had one movie that had Atmos issues and that was Free Guy. No other movie (even when ripped before the MakeMKV fix) glitched on my Yamaha. I guess the question is is it a MakeMKV problem (still not quite right with how the sync issues are handled), a Kodi issue or an AVR issue. I’m suspecting it’s a combination of the above and I’m just lucky to have an AVR that isn’t as picky about Atmos as some others are.
Thank you for trying, - really appreciate it. It is definitely a curious one, that’s for sure!
No problem. I wish I could help more. But we did learn one thing, TS2 did improve for you when you ripped with a newer version of MakeMKV.
I guess if you want to waste some time you could rip again, but instead of using the Default audio settings you could try FLAC I don’t know how well the Atmos would translate to 7.1 FLAC. I do have some 5.1 FLAC audio files and they sound great on my system.
Only so much brain power I can expend on this, but I have watched Encanto about 400x now without any glitches of any sort. I imagine this would have been a disaster on prior versions of OSMC and/or MakeMKV. :sweat_smile:
Thanks again.
