Wow, The Martian Extended Edition is truly a mess.
Name: The Martian Theatrical Edition (English)
Source file name: 00800.mpls
Duration: 2:21:37
Chapters count: 32
Segment count: 28
Segment map: 63,64,89,65,92,116,93,66,94,67,95,68,96,69,97,70,98,71,99,72,100,76,101,77,102,78,103,79
Name: The Martian Extended Edition (English)
Source file name: 00801.mpls
Duration: 2:31:20
Chapters count: 32
Segment count: 28
Segment map: 63,64,104,65,105,116,80,66,106,67,107,68,108,69,109,70,110,71,111,72,112,76,113,77,114,78,115,79
Both versions start off with 63 and 64 so who knows why they made those separate m2ts files.
But the version differences at the third segment with 89 versus 104 is where things get interesting.
The extended version is 20 seconds longer and shows the main character struggling to get out of bed.
But no matter what I do, the audio drops at the segment switch between 64 and 104, that’s approximately 18 minutes and 10 seconds into the film.
I can fast forward to the 17 minute mark and watch it happen repeatedly.
I made a remux with the latest MakeMKV 1.17.7 and I get this in the logs:
AV sync issue in stream 1 at 0:21:19.946 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +1.233ms
AV sync issue in stream 1 at 0:38:03.657 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.98ms
AV sync issue in stream 1 at 0:40:08.156 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.65ms
AV sync issue in stream 1 at 0:58:03.397 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.65ms
AV sync issue in stream 1 at 1:13:09.385 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.666ms
AV sync issue in stream 1 at 1:16:05.353 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.652ms
AV sync issue in stream 1 at 1:33:57.049 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +1.027ms
AV sync issue in stream 1 at 1:37:20.877 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.647ms
AV sync issue in stream 1 at 1:53:19.960 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.666ms
AV sync issue in stream 1 at 1:58:09.375 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.652ms
So I was expecting to see the beginning of many issues at 21 minutes and 19 seconds, which is where segment 65 meets segment 105, but that is after the 64/104 branch which clearly shows issues around 18 minutes and 10 seconds.
There were other issues as well but I’m just focusing on the first observed issue I noticed.
I tried using MLP to demux but that made no difference since MakeMKV apparently uses the MLP code to try and repair broken TrueHD branching.
This is from MLP’s GitHub page:
Notes for MakeMKV users
MakeMKV 1.15.4 and newer uses the same method for joining TrueHD streams, and should produce flawless TrueHD streams as well.
If only…
So I tried eac3to, same issue.
Then I tried DGDemux, same issue.
Then I tried using MKVToolNix 100%, which isn’t a big deal since the title is not Dolby Vision, and it got past the 64/104 branch without any issues, so I kept watching… it gets by the 65/105 branch but then it has an audio drop out at the 105/116 branch.
Very frustrating to say the least.
Did some more research and found online that a “release group” had an issue with this movie and they re-released a “proper” version to fix issues, but they never mentioned that audio drop outs were the issue.
They just said:
NOTES
Reason for PROPER: subs been out-of-sync - commentary audio too! Apologies for that, but
it seems demuxing subs/commentary with eac3to was a bad idea on this one!
This is now fully done in mkvtoolnix and tested!
So I “acquired” this “proper” “release” and it behaved exactly as my 100% MKVToolNix remux.
No real surprises there since their notes say they did their remux with MKVToolNix entirely as well.
Funny how they tried eac3to for their “original” “release”.
I haven’t tried using the Vero V to playback the entire disc in a folder since I haven’t had much luck with that in the past with branched discs, but if I run out of things to try I guess I’ll give it a shot.
I have one more thing I can think of to try before I get to that point though.
EDIT:
The MKVToolNix remux is by far the best results.
The audio drop outs few and far between.
When they happen they are almost unnoticeable, and I’m looking for them!
They tend to happen at moments where in the movie there is a hard cut edit from one camera to another so the super fast drop out almost feels like it’s part of the edit.
But many branches played seamlessly without drop outs.
Then the next drop out I saw was the 108/69 branch, which is pretty far along into the movie and my wife didn’t even catch it until I pointed it out to her and turned up the volume.
Very subtle but there.
I’m tired of watching this movie.
This is my verdict: If you own this disc and you want to remux the extended version then you should use MakeMKV to make a decrypted full backup of the disc to a folder and then use MKVToolNix to remux it.
It will not be perfect but it is very watchable and if you are not looking for the issue then you may not even notice it despite it being there.
Another note though with the MKVToolNix remux is that a little bit before one of these small audio drop outs happens it appears to skip a video frame, like the player has a hiccup when filling the buffer or something.
If I skip back and watch it again it doesn’t do it.
So who knows?
Definitely weird stuff going on.
My wife didn’t notice the hiccup before the audio drop outs either.
I’m super sensitive to frame rates, stutter, judder, and the like so I always catch that stuff.
Hopefully all this info is of some help to those struggling with this movie and for developers looking to fix this annoying TrueHD issue on their end.
