I like to avoid auto-mounting external drives when osmc boot or plug any unit. I like to mount units manually.
Thanks in advance
Try the following from the shell:
systemctl stop udisks-glue
systemctl disable udisks-glue.service
You don’t have to run the command each time you reboot…disable is permanent until the service is enabled again.
Thanks, it’s works
