Hello, I am running a pi3 and osmc and using exodus and salts both on trakt but have only really tested the exodus so far and it scrobbles just fine just never gives me a rating box either, in fact on my windows pc kodi machine same thing it works but no ratings box, I used to get them but not any more. I checked the website and it has the movies from a long time ago that I rated. I would be interested in this answer as well. Ok wanted to add just in case but did you change the indicator settings to trakt under the general setting just in case you were using exodus. If you were running from a local library then I need to learn.
Please do not talk about or promote banned repositories or addons!
http://kodi.wiki/view/Official:Forum_rules/Banned_add-ons
If you use stuff from this list it might be the cause of you problem and you will not get any support for it here.
Also, if you have a problem please give logs. It is nearly impossible to look into such errors without them. See here:
We have removed your thread from public viewing because it mentions a pirate addon. We cannot provide support for these. To get a better idea of our piracy policy, please see this link here FAQ - OSMC Forums
trakt.tv is a scrobbling and rating addon which is part of the official Kodi repositories. It is not a pirate addon.
This is why the thread was hidden.
This means that the issue is not an OSMC issue, you should take it up with the developers of the trakt addon.
And what about Exodus??
Exodus is a banned addon, is correct to ban the thread, but the real context of the question is for trakt.tv, so maybe the response of the ban can include some pointers to real solution. Being strict over Exodus only leaving behind the real question is stern. ActionA completed a few moments ago that, so there’s nothing more to say here.
The problem that i found is that this thread is used to not advance in the support of other trakt.tv thread, which by all means you can agree with me that is not fair. At least no without some explanation.
Your explanation is right here:
https://discourse.osmc.tv/faq#piracy
I’m sure you’re well aware that Exodus is an addon that provides pirated content, in accordance with our piracy policy this means the thread will be unlisted from public viewing as we can’t be seen to support or condone piracy. End of discussion.
