Hello, today I updated my Vero2 via OSMC with the march update.
I can navigate through my library and menus, but when I start any kind of video (HD or SD) the player stucks with the two blue circles rotating and the video doesn’t start.
I have to unplug the Vero2 because it becomes irresponsive.
I uploaded two logs: http://paste.osmc.tv/yosogehele http://paste.osmc.tv/sonufovugu
I can see some errors in the first one, for example:
I have a centralized database for Kodi in my server and it always worked fine until today.
When I try to play a video from my PC with Kodi for Windows, it plays well.
Could someone help me, please?
Thank you very much
I tried other files on NAS, same problem.
I tried now an .mkv file from a USB drive (Succession.2x03) and it can’t be played too. http://paste.osmc.tv/ikeretepoq
What could it be?
My Vero2 plays content (MKV video files and FLAC music files) from an SMB share from a Synology NAS. All working fine until today.
Now (after the update) I can still browse around the SMB folders, but when I select a file to play (video or music), the Vero2 GUI shows an animated icon that reminds me of the Windows egg timer, then after maybe 20 seconds, it returns to the list of files without playing anything.
The Synology OS has not been patched since November - and it still serves content happily to other SMB clients e.g. using VLC. I tried rebooting the Synology and the Vero2, but that didn’t help!
Hopefully your fix for rodrisco will fix my problem as well?
Hi I have the same issue too after upgrading to the latest March update, I have the 1st gen Vero:
DEBUG: Open - av_find_stream_info finished
2020-03-26 09:57:23.709 T:2303836896 INFO: ffmpeg[8951C2E0]: Input #0, ac3, from ‘smb://192.168.1.200/Streaming/My Films/Ben Is Back (2018)/Ben Is Back (2018).mkv’:
2020-03-26 09:57:23.710 T:2303836896 INFO: ffmpeg[8951C2E0]: Duration: 259:12:35.08, start: 0.000000, bitrate: 191 kb/s
2020-03-26 09:57:23.710 T:2303836896 INFO: ffmpeg[8951C2E0]: Stream #0:0: Audio: eac3, 48000 Hz, stereo, fltp, 192 kb/s
2020-03-26 09:57:23.710 T:2303836896 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
2020-03-26 09:57:24.895 T:2303836896 DEBUG: ffmpeg[8951C2E0]: Format ac3 detected only with low score of 25, misdetection possible!
2020-03-26 09:57:24.895 T:2303836896 DEBUG: Open - probing detected format [ac3]
2020-03-26 09:57:24.896 T:2303836896 DEBUG: Open - avformat_find_stream_info starting
2020-03-26 09:57:25.095 T:2303836896 ERROR: ffmpeg[8951C2E0]: [ac3] frame sync error
2020-03-26 09:57:25.153 T:2303836896 DEBUG: ffmpeg[8951C2E0]: [ac3] Additional substreams is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
2020-03-26 09:57:25.154 T:2303836896 DEBUG: ffmpeg[8951C2E0]: [ac3] If you want to help, upload a sample of this file to ftp://upload.ffmpeg.org/incoming/ and contact the ffmpeg-devel mailing list. (ffmpeg-devel@ffmpeg.org)
2020-03-26 09:57:25.218 T:2303836896 ERROR: ffmpeg[8951C2E0]: [ac3] expacc 127 is out-of-range
2020-03-26 09:57:25.219 T:2303836896 ERROR: ffmpeg[8951C2E0]: [ac3] error decoding the audio block
2020-03-26 09:57:27.241 T:2303836896 DEBUG: Open - av_find_stream_info finished
2020-03-26 09:57:27.242 T:2303836896 INFO: ffmpeg[8951C2E0]: Input #0, ac3, from ‘smb://192.168.1.200/Streaming/My Films/Ben Is Back (2018)/Ben Is Back (2018).mkv’:
2020-03-26 09:57:27.242 T:2303836896 INFO: ffmpeg[8951C2E0]: Duration: N/A, start: 0.000000, bitrate: N/A
2020-03-26 09:57:27.242 T:2303836896 INFO: ffmpeg[8951C2E0]: Stream #0:0: Audio: eac3, 44100 Hz, 2.1, fltp
2020-03-26 09:57:27.242 T:2303836896 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
2020-03-26 09:57:28.405 T:2303836896 ERROR: Open - error probing input format, smb://192.168.1.200/Streaming/My Films/Ben Is Back (2018)/Ben Is Back (2018).mkv
2020-03-26 09:57:28.406 T:2303836896 ERROR: OpenDemuxStream - Error creating demuxer
2020-03-26 09:57:28.406 T:2303836896 NOTICE: CVideoPlayer::OnExit()
2020-03-26 09:57:28.407 T:2606748384 DEBUG: Thread JobWorker start, auto delete: true
2020-03-26 09:57:28.408 T:2303836896 DEBUG: CSMBFile::Close closing fd 10000
I have the same error message too. Hope Sam gets well and gives us a fix!
