I use the Vero V to listen to music over bluetooth from multiple Android phones that may connect to it and regardless of the phone, the following happens.
Scenario 1: If I 1) connect Android via bluetooth to Vero V and 2) fire up music app and play music, all works fine.
Scenario 2: But if I 1) play music on phone and 2) connect phone via bluetooth to Vero V, there is about 2 seconds of music playing over bluetooth and then no more music, even though it still shows as playing on my phone.
I toyed with the Developer options on Android and found that only one of all the available options can fix the issue if I ever find myself in Scenario 2. It’s changing the default AAC Bluetooth audio codec to SBC. Whenever I do this AAC - > SBC codec transition in the settings, problem is fixed. If I transition from SBC → AAC codec, no music comes out of Vero V even though phone is still playing it.
So, I took this dmesg snapshot while doing such transitions, I annotated it with some comments:
############### At this point, music is playing on Android phone and I connect via bluetooth to Vero V:
[959545.836854] aml_tdm_open opening tdm id 2
[959545.837334] audio_ddr_mngr: frddrs[1] registered by device fe330000.audiobus:tdm@2
[959545.839289] set mclk:11289600, mpll:22579200, get mclk:11289593, mpll:22579186
[959545.839298] asoc aml_dai_set_tdm_fmt, 0x4001, 000000009cc193cb, id(2), clksel(2)
[959545.839301] aml_tdm_set_fmt(), fmt not change
[959545.839308] dump_pcm_setting(000000009cc193cb)
[959545.839310] pcm_mode(1)
[959545.839312] sysclk(11289600)
[959545.839314] sysclk_bclk_ratio(4)
[959545.839316] bclk(2822400)
[959545.839317] bclk_lrclk_ratio(64)
[959545.839319] lrclk(44100)
[959545.839321] tx_mask(0x3)
[959545.839322] rx_mask(0x3)
[959545.839324] slots(2)
[959545.839325] slot_width(32)
[959545.839327] lane_mask_in(0x0)
[959545.839329] lane_mask_out(0xf)
[959545.839331] lane_oe_mask_in(0x0)
[959545.839332] lane_oe_mask_out(0x0)
[959545.839340] lane_lb_mask_in(0x0)
[959545.839345] set mclk:11289600, mpll:22579200, get mclk:11289593, mpll:22579186
[959545.839348] aml_tdm_set_clkdiv, div 4, clksel(2)
[959545.839354] aml_set_bclk_ratio, select I2S mode
[959545.839361] aml_tdm_hw_setting_init(), enable mclk for tdm-2
[959545.839460] aml_tdm_prepare(), reset fddr
[959545.839476] ss_prepare() 247, lvl 1
[959545.839482] spdif_a fifo ctrl, frddr:1 type:1, 16 bits, chmask 0x3, swap 0x10
[959545.839490] iec_info: rate: 44100, codec_type:0x0, channel status L:0x100, R:0x100
[959545.839495] hdmitx: audio: aout notify rate 44100
[959545.839497] hdmitx: audio: aout notify size 16
[959545.839501] hdmitx: audio: aout notify sample size 1 was 4
[959545.839503] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959545.839508] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959545.839526] hdmitx: audio: aout notify rate 44100
[959545.839528] hdmitx: audio: aout notify size 16
[959545.839530] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959545.840845] tdm playback mute: 0, lane_cnt = 4
[959545.840885] aml_tdm_prepare(), reset fddr
[959545.840900] ss_prepare() 247, lvl 1
[959545.840906] spdif_a fifo ctrl, frddr:1 type:1, 16 bits, chmask 0x3, swap 0x10
[959545.840913] iec_info: rate: 44100, codec_type:0x0, channel status L:0x100, R:0x100
[959545.840923] hdmitx: audio: aout notify rate 44100
[959545.840925] hdmitx: audio: aout notify size 16
[959545.840929] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959545.840933] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959545.840953] hdmitx: audio: aout notify rate 44100
[959545.840955] hdmitx: audio: aout notify size 16
[959545.840957] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959545.841146] tdm playback mute: 0, lane_cnt = 4
[959546.337824] asoc-aml-card auge_sound: TDM[2] Playback enable
[959546.337834] ss_trigger() ss 3
[959546.337838] spdif_a is set to enable
[959546.337947] ss_mute() 364, mute 0, id 0
[959548.166686] input: Willie Trombone (AVRCP) as /devices/virtual/input/input42
[959548.965333] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959548.966461] audio_ddr_mngr: frddrs[2] registered by device fe330000.audiobus:spdif@0
[959548.966468] aml_spdif_open opening spdif id 0 IEC codec type 0
[959548.968067] spdif_a keep clk continuous
[959548.968757] audio_ddr_mngr: frddrs[2] released by device fe330000.audiobus:spdif@0
[959548.971503] audio_dsp: buf=0
[959548.971510] audio_dsp: IEC958_mode_raw=0
[959548.971550] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959548.971552] audio_dsp: last mode 0,now 0
[959548.971652] hdmitx: hdmitx: config: audio_on
[959548.971658] hdmitx: audio: configure on
[959548.977579] audio_dsp: buf=0
[959548.977586] audio_dsp: IEC958_mode_raw=0
[959548.977618] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959548.977621] audio_dsp: last mode 0,now 0
[959548.977865] hdmitx: hdmitx: config: audio_on
[959548.977872] hdmitx: audio: configure on
[959549.488219] audio_dsp: buf=0
[959549.488227] audio_dsp: IEC958_mode_raw=0
[959549.488273] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959549.488276] audio_dsp: last mode 0,now 0
[959549.488402] hdmitx: hdmitx: config: audio_on
[959549.488408] hdmitx: audio: configure on
[959549.499211] audio_dsp: buf=0
[959549.499219] audio_dsp: IEC958_mode_raw=0
[959549.499320] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959549.499324] audio_dsp: last mode 0,now 0
[959549.499483] hdmitx: hdmitx: config: audio_on
[959549.499491] hdmitx: audio: configure on
[959550.007714] audio_dsp: buf=0
[959550.007722] audio_dsp: IEC958_mode_raw=0
[959550.007768] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959550.007772] audio_dsp: last mode 0,now 0
[959550.008076] hdmitx: hdmitx: config: audio_on
[959550.008084] hdmitx: audio: configure on
[959550.029007] audio_dsp: buf=0
[959550.029015] audio_dsp: IEC958_mode_raw=0
[959550.029051] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959550.029054] audio_dsp: last mode 0,now 0
[959550.029183] hdmitx: hdmitx: config: audio_on
[959550.029190] hdmitx: audio: configure on
[959550.540046] audio_dsp: buf=0
[959550.540054] audio_dsp: IEC958_mode_raw=0
[959550.540100] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959550.540103] audio_dsp: last mode 0,now 0
[959550.540241] hdmitx: hdmitx: config: audio_on
[959550.540248] hdmitx: audio: configure on
[959550.547621] audio_dsp: buf=0
[959550.547629] audio_dsp: IEC958_mode_raw=0
[959550.547665] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959550.547669] audio_dsp: last mode 0,now 0
[959550.547792] hdmitx: hdmitx: config: audio_on
[959550.547799] hdmitx: audio: configure on
[959551.056399] audio_dsp: buf=0
[959551.056407] audio_dsp: IEC958_mode_raw=0
[959551.056456] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959551.056459] audio_dsp: last mode 0,now 0
[959551.056614] hdmitx: hdmitx: config: audio_on
[959551.056621] hdmitx: audio: configure on
[959551.064222] audio_dsp: buf=0
[959551.064230] audio_dsp: IEC958_mode_raw=0
[959551.064267] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959551.064270] audio_dsp: last mode 0,now 0
[959551.064401] hdmitx: hdmitx: config: audio_on
[959551.064409] hdmitx: audio: configure on
[959551.571999] audio_dsp: buf=0
[959551.572007] audio_dsp: IEC958_mode_raw=0
[959551.572052] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959551.572056] audio_dsp: last mode 0,now 0
[959551.572185] hdmitx: hdmitx: config: audio_on
[959551.572192] hdmitx: audio: configure on
[959551.579129] audio_dsp: buf=0
[959551.579137] audio_dsp: IEC958_mode_raw=0
[959551.579173] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959551.579176] audio_dsp: last mode 0,now 0
[959551.579393] hdmitx: hdmitx: config: audio_on
[959551.579405] hdmitx: audio: configure on
[959552.087969] audio_dsp: buf=0
[959552.087978] audio_dsp: IEC958_mode_raw=0
[959552.088024] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959552.088027] audio_dsp: last mode 0,now 0
[959552.088172] hdmitx: hdmitx: config: audio_on
[959552.088180] hdmitx: audio: configure on
[959552.095410] audio_dsp: buf=0
[959552.095417] audio_dsp: IEC958_mode_raw=0
[959552.095453] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959552.095456] audio_dsp: last mode 0,now 0
[959552.095579] hdmitx: hdmitx: config: audio_on
[959552.095586] hdmitx: audio: configure on
[959552.605986] audio_dsp: buf=0
[959552.605994] audio_dsp: IEC958_mode_raw=0
[959552.606039] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959552.606043] audio_dsp: last mode 0,now 0
[959552.606171] hdmitx: hdmitx: config: audio_on
[959552.606178] hdmitx: audio: configure on
[959552.620832] audio_dsp: buf=0
[959552.620840] audio_dsp: IEC958_mode_raw=0
[959552.620880] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959552.620883] audio_dsp: last mode 0,now 0
[959552.621016] hdmitx: hdmitx: config: audio_on
[959552.621023] hdmitx: audio: configure on
[959553.128959] audio_dsp: buf=0
[959553.128967] audio_dsp: IEC958_mode_raw=0
[959553.129010] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959553.129014] audio_dsp: last mode 0,now 0
[959553.129158] hdmitx: hdmitx: config: audio_on
[959553.129165] hdmitx: audio: configure on
[959553.135808] audio_dsp: buf=0
[959553.135815] audio_dsp: IEC958_mode_raw=0
[959553.135850] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959553.135852] audio_dsp: last mode 0,now 0
[959553.135971] hdmitx: hdmitx: config: audio_on
[959553.135978] hdmitx: audio: configure on
[959553.645350] audio_dsp: buf=0
[959553.645358] audio_dsp: IEC958_mode_raw=0
[959553.645405] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959553.645408] audio_dsp: last mode 0,now 0
[959553.645541] hdmitx: hdmitx: config: audio_on
[959553.645549] hdmitx: audio: configure on
[959553.653475] audio_dsp: buf=0
[959553.653482] audio_dsp: IEC958_mode_raw=0
[959553.653523] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959553.653526] audio_dsp: last mode 0,now 0
[959553.653660] hdmitx: hdmitx: config: audio_on
[959553.653666] hdmitx: audio: configure on
[959554.164952] audio_dsp: buf=0
[959554.164960] audio_dsp: IEC958_mode_raw=0
[959554.165005] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959554.165008] audio_dsp: last mode 0,now 0
[959554.165134] hdmitx: hdmitx: config: audio_on
[959554.165140] hdmitx: audio: configure on
[959554.174426] audio_dsp: buf=0
[959554.174435] audio_dsp: IEC958_mode_raw=0
[959554.174474] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959554.174477] audio_dsp: last mode 0,now 0
[959554.174590] hdmitx: hdmitx: config: audio_on
[959554.174596] hdmitx: audio: configure on
[959554.683049] audio_dsp: buf=0
[959554.683057] audio_dsp: IEC958_mode_raw=0
[959554.683103] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959554.683107] audio_dsp: last mode 0,now 0
[959554.683243] hdmitx: hdmitx: config: audio_on
[959554.683249] hdmitx: audio: configure on
[959554.692161] audio_dsp: buf=0
[959554.692169] audio_dsp: IEC958_mode_raw=0
[959554.692208] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959554.692211] audio_dsp: last mode 0,now 0
[959554.692325] hdmitx: hdmitx: config: audio_on
[959554.692332] hdmitx: audio: configure on
[959555.201262] audio_dsp: buf=0
[959555.201271] audio_dsp: IEC958_mode_raw=0
[959555.201317] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959555.201321] audio_dsp: last mode 0,now 0
[959555.201468] hdmitx: hdmitx: config: audio_on
[959555.201476] hdmitx: audio: configure on
[959555.208154] audio_dsp: buf=0
[959555.208162] audio_dsp: IEC958_mode_raw=0
[959555.208200] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959555.208203] audio_dsp: last mode 0,now 0
[959555.208325] hdmitx: hdmitx: config: audio_on
[959555.208332] hdmitx: audio: configure on
[959555.717752] audio_dsp: buf=0
[959555.717760] audio_dsp: IEC958_mode_raw=0
[959555.717805] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959555.717809] audio_dsp: last mode 0,now 0
[959555.717939] hdmitx: hdmitx: config: audio_on
[959555.717946] hdmitx: audio: configure on
[959555.726540] audio_dsp: buf=0
[959555.726548] audio_dsp: IEC958_mode_raw=0
[959555.726589] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959555.726592] audio_dsp: last mode 0,now 0
[959555.726761] hdmitx: hdmitx: config: audio_on
[959555.726767] hdmitx: audio: configure on
[959556.236146] audio_dsp: buf=0
[959556.236154] audio_dsp: IEC958_mode_raw=0
[959556.236201] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959556.236205] audio_dsp: last mode 0,now 0
[959556.236354] hdmitx: hdmitx: config: audio_on
[959556.236361] hdmitx: audio: configure on
[959556.245004] audio_dsp: buf=0
[959556.245013] audio_dsp: IEC958_mode_raw=0
[959556.245050] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959556.245053] audio_dsp: last mode 0,now 0
[959556.245734] hdmitx: hdmitx: config: audio_on
[959556.245740] hdmitx: audio: configure on
[959556.754403] audio_dsp: buf=0
[959556.754411] audio_dsp: IEC958_mode_raw=0
[959556.754452] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959556.754455] audio_dsp: last mode 0,now 0
[959556.754567] hdmitx: hdmitx: config: audio_on
[959556.754573] hdmitx: audio: configure on
[959556.763096] audio_dsp: buf=0
[959556.763105] audio_dsp: IEC958_mode_raw=0
[959556.763143] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959556.763146] audio_dsp: last mode 0,now 0
[959556.763266] hdmitx: hdmitx: config: audio_on
[959556.763272] hdmitx: audio: configure on
[959557.271577] audio_dsp: buf=0
[959557.271585] audio_dsp: IEC958_mode_raw=0
[959557.271633] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959557.271636] audio_dsp: last mode 0,now 0
[959557.271783] hdmitx: hdmitx: config: audio_on
[959557.271790] hdmitx: audio: configure on
[959557.278926] audio_dsp: buf=0
[959557.278933] audio_dsp: IEC958_mode_raw=0
[959557.278971] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959557.278974] audio_dsp: last mode 0,now 0
[959557.279090] hdmitx: hdmitx: config: audio_on
[959557.279096] hdmitx: audio: configure on
[959557.789850] audio_dsp: buf=0
[959557.789858] audio_dsp: IEC958_mode_raw=0
[959557.789899] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959557.789903] audio_dsp: last mode 0,now 0
[959557.790015] hdmitx: hdmitx: config: audio_on
[959557.790021] hdmitx: audio: configure on
[959557.796680] audio_dsp: buf=0
[959557.796688] audio_dsp: IEC958_mode_raw=0
[959557.796724] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959557.796727] audio_dsp: last mode 0,now 0
[959557.796838] hdmitx: hdmitx: config: audio_on
[959557.796844] hdmitx: audio: configure on
[959558.307597] audio_dsp: buf=0
[959558.307605] audio_dsp: IEC958_mode_raw=0
[959558.307652] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959558.307656] audio_dsp: last mode 0,now 0
[959558.307805] hdmitx: hdmitx: config: audio_on
[959558.307813] hdmitx: audio: configure on
[959558.315853] audio_dsp: buf=0
[959558.315861] audio_dsp: IEC958_mode_raw=0
[959558.315897] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959558.315900] audio_dsp: last mode 0,now 0
[959558.316014] hdmitx: hdmitx: config: audio_on
[959558.316019] hdmitx: audio: configure on
[959558.824318] audio_dsp: buf=0
[959558.824324] audio_dsp: IEC958_mode_raw=0
[959558.824351] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959558.824353] audio_dsp: last mode 0,now 0
[959558.824439] hdmitx: hdmitx: config: audio_on
[959558.824445] hdmitx: audio: configure on
[959558.829247] audio_dsp: buf=0
[959558.829253] audio_dsp: IEC958_mode_raw=0
[959558.829279] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959558.829281] audio_dsp: last mode 0,now 0
[959558.829365] hdmitx: hdmitx: config: audio_on
[959558.829369] hdmitx: audio: configure on
[959559.342212] audio_dsp: buf=0
[959559.342220] audio_dsp: IEC958_mode_raw=0
[959559.342265] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959559.342268] audio_dsp: last mode 0,now 0
[959559.342417] hdmitx: hdmitx: config: audio_on
[959559.342423] hdmitx: audio: configure on
[959559.349337] audio_dsp: buf=0
[959559.349345] audio_dsp: IEC958_mode_raw=0
[959559.350841] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959559.350847] audio_dsp: last mode 0,now 0
[959559.351037] hdmitx: hdmitx: config: audio_on
[959559.351043] hdmitx: audio: configure on
[959559.858281] audio_dsp: buf=0
[959559.858289] audio_dsp: IEC958_mode_raw=0
[959559.858330] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959559.858333] audio_dsp: last mode 0,now 0
[959559.858445] hdmitx: hdmitx: config: audio_on
[959559.858450] hdmitx: audio: configure on
[959559.868704] audio_dsp: buf=0
[959559.868713] audio_dsp: IEC958_mode_raw=0
[959559.868751] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959559.868754] audio_dsp: last mode 0,now 0
[959559.868871] hdmitx: hdmitx: config: audio_on
[959559.868877] hdmitx: audio: configure on
[959560.379152] audio_dsp: buf=0
[959560.379160] audio_dsp: IEC958_mode_raw=0
[959560.379206] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959560.379210] audio_dsp: last mode 0,now 0
[959560.379358] hdmitx: hdmitx: config: audio_on
[959560.379365] hdmitx: audio: configure on
[959560.387672] audio_dsp: buf=0
[959560.387681] audio_dsp: IEC958_mode_raw=0
[959560.387717] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959560.387720] audio_dsp: last mode 0,now 0
[959560.387832] hdmitx: hdmitx: config: audio_on
[959560.387838] hdmitx: audio: configure on
[959560.896414] audio_dsp: buf=0
[959560.896422] audio_dsp: IEC958_mode_raw=0
[959560.896462] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959560.896465] audio_dsp: last mode 0,now 0
[959560.896582] hdmitx: hdmitx: config: audio_on
[959560.896588] hdmitx: audio: configure on
[959560.904714] audio_dsp: buf=0
[959560.904722] audio_dsp: IEC958_mode_raw=0
[959560.904758] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959560.904761] audio_dsp: last mode 0,now 0
[959560.904877] hdmitx: hdmitx: config: audio_on
[959560.904884] hdmitx: audio: configure on
[959561.415035] audio_dsp: buf=0
[959561.415043] audio_dsp: IEC958_mode_raw=0
[959561.415090] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959561.415094] audio_dsp: last mode 0,now 0
[959561.415245] hdmitx: hdmitx: config: audio_on
[959561.415252] hdmitx: audio: configure on
[959561.424608] audio_dsp: buf=0
[959561.424616] audio_dsp: IEC958_mode_raw=0
[959561.424650] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959561.424653] audio_dsp: last mode 0,now 0
[959561.424768] hdmitx: hdmitx: config: audio_on
[959561.424774] hdmitx: audio: configure on
[959561.933043] audio_dsp: buf=0
[959561.933051] audio_dsp: IEC958_mode_raw=0
[959561.933091] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959561.933095] audio_dsp: last mode 0,now 0
[959561.933204] hdmitx: hdmitx: config: audio_on
[959561.933211] hdmitx: audio: configure on
[959561.941477] audio_dsp: buf=0
[959561.941484] audio_dsp: IEC958_mode_raw=0
[959561.941523] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959561.941526] audio_dsp: last mode 0,now 0
[959561.941709] hdmitx: hdmitx: config: audio_on
[959561.941715] hdmitx: audio: configure on
[959562.451340] audio_dsp: buf=0
[959562.451348] audio_dsp: IEC958_mode_raw=0
[959562.451393] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959562.451397] audio_dsp: last mode 0,now 0
[959562.451546] hdmitx: hdmitx: config: audio_on
[959562.451553] hdmitx: audio: configure on
[959562.459700] audio_dsp: buf=0
[959562.459708] audio_dsp: IEC958_mode_raw=0
[959562.459745] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959562.459748] audio_dsp: last mode 0,now 0
[959562.459864] hdmitx: hdmitx: config: audio_on
[959562.459870] hdmitx: audio: configure on
[959562.966898] audio_dsp: buf=0
[959562.966906] audio_dsp: IEC958_mode_raw=0
[959562.966946] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959562.966949] audio_dsp: last mode 0,now 0
[959562.967061] hdmitx: hdmitx: config: audio_on
[959562.967067] hdmitx: audio: configure on
[959562.975595] audio_dsp: buf=0
[959562.975603] audio_dsp: IEC958_mode_raw=0
[959562.975638] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959562.975641] audio_dsp: last mode 0,now 0
[959562.975754] hdmitx: hdmitx: config: audio_on
[959562.975760] hdmitx: audio: configure on
[959563.485920] audio_dsp: buf=0
[959563.485928] audio_dsp: IEC958_mode_raw=0
[959563.485973] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959563.485976] audio_dsp: last mode 0,now 0
[959563.486176] hdmitx: hdmitx: config: audio_on
[959563.486183] hdmitx: audio: configure on
[959563.495950] audio_dsp: buf=0
[959563.495958] audio_dsp: IEC958_mode_raw=0
[959563.495994] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959563.495997] audio_dsp: last mode 0,now 0
[959563.496114] hdmitx: hdmitx: config: audio_on
[959563.496120] hdmitx: audio: configure on
############### Here I use Developer Options on Android to change Bluetooth codec from SBC -> AAC, music still doesn't play through the Vero V but at least the dmesg spam is stopped:
[959563.533595] asoc-aml-card auge_sound: TDM[2] Playback stop
[959563.533605] ss_mute() 364, mute 1, id 0
[959563.533616] ss_trigger() ss 3
[959563.533619] spdif_a is set to disable
[959563.533631] audio_ddr_mngr: frddr stop success, fifo id 1, regbase:0x80, arb sts:0x40000020
[959563.533681] ss_free() lvl 1
[959563.533687] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959563.533692] aml_tdm_hw_setting_free(), disable mclk for tdm-2
[959563.533718] tdm playback mute: 1, lane_cnt = 4
[959563.534155] audio_ddr_mngr: frddrs[1] released by device fe330000.audiobus:tdm@2
[959564.004818] audio_dsp: buf=0
[959564.004827] audio_dsp: IEC958_mode_raw=0
[959564.004873] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[959564.004877] audio_dsp: last mode 0,now 0
[959564.004999] hdmitx: hdmitx: config: audio_on
[959564.005006] hdmitx: audio: configure on
[959564.013037] aml_tdm_open opening tdm id 2
[959564.013564] audio_ddr_mngr: frddrs[1] registered by device fe330000.audiobus:tdm@2
[959564.015644] set mclk:11289600, mpll:22579200, get mclk:11289593, mpll:22579186
[959564.015654] asoc aml_dai_set_tdm_fmt, 0x4001, 000000009cc193cb, id(2), clksel(2)
[959564.015657] aml_tdm_set_fmt(), fmt not change
[959564.015665] dump_pcm_setting(000000009cc193cb)
[959564.015667] pcm_mode(1)
[959564.015669] sysclk(11289600)
[959564.015671] sysclk_bclk_ratio(4)
[959564.015674] bclk(2822400)
[959564.015676] bclk_lrclk_ratio(64)
[959564.015678] lrclk(44100)
[959564.015680] tx_mask(0x3)
[959564.015682] rx_mask(0x3)
[959564.015684] slots(2)
[959564.015686] slot_width(32)
[959564.015688] lane_mask_in(0x0)
[959564.015690] lane_mask_out(0xf)
[959564.015692] lane_oe_mask_in(0x0)
[959564.015694] lane_oe_mask_out(0x0)
[959564.015696] lane_lb_mask_in(0x0)
[959564.015702] set mclk:11289600, mpll:22579200, get mclk:11289593, mpll:22579186
[959564.015705] aml_tdm_set_clkdiv, div 4, clksel(2)
[959564.015713] aml_set_bclk_ratio, select I2S mode
[959564.015721] aml_tdm_hw_setting_init(), enable mclk for tdm-2
[959564.015826] aml_tdm_prepare(), reset fddr
[959564.015843] ss_prepare() 247, lvl 1
[959564.015850] spdif_a fifo ctrl, frddr:1 type:4, 24 bits, chmask 0x3, swap 0x10
[959564.015859] iec_info: rate: 44100, codec_type:0x0, channel status L:0x100, R:0x100
[959564.015865] hdmitx: audio: aout notify rate 44100
[959564.015867] hdmitx: audio: aout notify size 32
[959564.015872] hdmitx: audio: aout notify sample size 4 was 1
[959564.015875] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959564.015880] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959564.015905] hdmitx: audio: aout notify rate 44100
[959564.015908] hdmitx: audio: aout notify size 32
[959564.015911] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959564.016158] tdm playback mute: 0, lane_cnt = 4
[959564.016331] hdmitx: sysfs set hdmi_ch to 0
[959564.016416] aml_tdm_prepare(), reset fddr
[959564.016431] ss_prepare() 247, lvl 1
[959564.016438] spdif_a fifo ctrl, frddr:1 type:4, 24 bits, chmask 0x3, swap 0x10
[959564.016445] iec_info: rate: 44100, codec_type:0x0, channel status L:0x100, R:0x100
[959564.016449] hdmitx: audio: aout notify rate 44100
[959564.016452] hdmitx: audio: aout notify size 32
[959564.016455] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959564.016459] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959564.016475] hdmitx: audio: aout notify rate 44100
[959564.016478] hdmitx: audio: aout notify size 32
[959564.016481] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959564.016874] tdm playback mute: 0, lane_cnt = 4
[959564.019076] ss_free() lvl 1
[959564.019086] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959564.019097] aml_tdm_hw_setting_free(), disable mclk for tdm-2
[959564.019129] tdm playback mute: 1, lane_cnt = 4
[959564.019200] audio_ddr_mngr: frddrs[1] released by device fe330000.audiobus:tdm@2
[959566.198479] input: Willie Trombone (AVRCP) as /devices/virtual/input/input43
############### Here I switch back from AAC - > SBC in developer options on Android and music starts playing normal, so it seems the AAC -> SBC transition always does the trick:
[959574.092923] aml_tdm_open opening tdm id 2
[959574.093308] audio_ddr_mngr: frddrs[1] registered by device fe330000.audiobus:tdm@2
[959574.094699] set mclk:11289600, mpll:22579200, get mclk:11289593, mpll:22579186
[959574.094707] asoc aml_dai_set_tdm_fmt, 0x4001, 000000009cc193cb, id(2), clksel(2)
[959574.094709] aml_tdm_set_fmt(), fmt not change
[959574.094715] dump_pcm_setting(000000009cc193cb)
[959574.094716] pcm_mode(1)
[959574.094717] sysclk(11289600)
[959574.094719] sysclk_bclk_ratio(4)
[959574.094720] bclk(2822400)
[959574.094721] bclk_lrclk_ratio(64)
[959574.094722] lrclk(44100)
[959574.094724] tx_mask(0x3)
[959574.094725] rx_mask(0x3)
[959574.094726] slots(2)
[959574.094727] slot_width(32)
[959574.094728] lane_mask_in(0x0)
[959574.094729] lane_mask_out(0xf)
[959574.094731] lane_oe_mask_in(0x0)
[959574.094732] lane_oe_mask_out(0x0)
[959574.094733] lane_lb_mask_in(0x0)
[959574.094737] set mclk:11289600, mpll:22579200, get mclk:11289593, mpll:22579186
[959574.094739] aml_tdm_set_clkdiv, div 4, clksel(2)
[959574.094744] aml_set_bclk_ratio, select I2S mode
[959574.094750] aml_tdm_hw_setting_init(), enable mclk for tdm-2
[959574.094835] aml_tdm_prepare(), reset fddr
[959574.094849] ss_prepare() 247, lvl 1
[959574.094854] spdif_a fifo ctrl, frddr:1 type:1, 16 bits, chmask 0x3, swap 0x10
[959574.094859] iec_info: rate: 44100, codec_type:0x0, channel status L:0x100, R:0x100
[959574.094864] hdmitx: audio: aout notify rate 44100
[959574.094866] hdmitx: audio: aout notify size 16
[959574.094868] hdmitx: audio: aout notify sample size 1 was 4
[959574.094870] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959574.094874] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959574.094890] hdmitx: audio: aout notify rate 44100
[959574.094891] hdmitx: audio: aout notify size 16
[959574.094893] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959574.095055] tdm playback mute: 0, lane_cnt = 4
[959574.095078] aml_tdm_prepare(), reset fddr
[959574.095089] ss_prepare() 247, lvl 1
[959574.095094] spdif_a fifo ctrl, frddr:1 type:1, 16 bits, chmask 0x3, swap 0x10
[959574.095099] iec_info: rate: 44100, codec_type:0x0, channel status L:0x100, R:0x100
[959574.095103] hdmitx: audio: aout notify rate 44100
[959574.095104] hdmitx: audio: aout notify size 16
[959574.095107] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959574.095109] audio_ddr_mngr: frddr_set_sharebuffer_enable share lvl: 1, dst_src: 3
[959574.095122] hdmitx: audio: aout notify rate 44100
[959574.095124] hdmitx: audio: aout notify size 16
[959574.095125] hdmitx: audio: hdmi_ch: 0 speaker_layout: 0
[959574.095250] tdm playback mute: 0, lane_cnt = 4
[959574.591024] asoc-aml-card auge_sound: TDM[2] Playback enable
[959574.591033] ss_trigger() ss 3
[959574.591038] spdif_a is set to enable
[959574.591148] ss_mute() 364, mute 0, id 0
[959576.142869] input: Willie Trombone (AVRCP) as /devices/virtual/input/input44
