Hello there !
I am trying to connect my JBL FLIP 4 bluetooth speaker to my Raspberry pi 3B under OSMC (latest version).
It is a new clean install. I managed to connect the speaker using a2dp, and it connects automatically when i turn it on. However, the sound is still coming from the tv trough HDMI, although the Alsa PulseAudio sound server is selected as sound output.
If i go back to this settings and select it again, then there is no more sound from HDMI and the speaker still doesn’t play sound.
When I turn off the speaker, sound goes back to HDMI.
I still have an issue regarding bluetooth connection with speaker :
When I turn on the speaker, the sound still goes through hdmi. I have to go to audio settings, change ouptu to hdmi and change it back to PulseAudio.
Is there anything I can do about it ?
Not sure why that is the case it worked automatically for me. No direct solution but the team is working on a new bluetooth approach and that would most likely solve your issue.
I’m also having some trouble with my JBL Flip 4 speaker. It paired no problem and says audio is going through the pulseaudio output, but the sound is still using the HDMI connection.
When I run pactl list sources short without the speaker connected I get
‘0 alsa_output.platform-aml_m8_snd.46.analog-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz IDLE
1 alsa_input.platform-aml_m8_snd.46.analog-stereo module-alsa-card.c s16le 2ch 44100Hz IDLE’
When the speaker is connected I get
‘0 alsa_output.platform-aml_m8_snd.46.analog-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
1 alsa_input.platform-aml_m8_snd.46.analog-stereo module-alsa-card.c s16le 2ch 44100Hz SUSPENDED’
This looks like you haven’t installed the a2dp app.
So either install it via sudo apt-get install a2dp-app-osmc alternatively we are moving on to a new bluez based solution. If you haven’t installed a2dp so far and directly want to jump on the new train let me know and I write you those steps.
If you don’t mind writing it out for me, that would be great! I just started using my vero yesterday and spent most of today trying to figure this out. Thank you!
So you confirm you haven’t installed a2dp-app-osmc so far? Because otherwise you first need to uninstall that.
You can check with dpkg -l | grep a2dp if reply is empty it is not installed.
That should give you the baseline. You then would need to edit/create the profile with nano .asoundrc with the following content (adapt/replace the fields in the <>
# This file describes the bluetooth sinks available for Kodi to play to
# add lines like the following for each BT device (speaker or headphones)
pcm.mybtdevice {
type bluealsa
device "<DEVICE MAC>"
profile "a2dp"
hint {show on description "<SIMPLE NAME>"}
# using the MAC of the device (see bluetoothctl) instead of 12:34:56:78:9A:BC
# Use any letters or numbers for the description which will show up in Settings-System-Audio
After that I suggest to reboot. You then should have an entry in Kodi under Audio device that shows what you choose as <SIMPLE NAME>
So I did all that and it’s still not working. Under my audio outputs my two options are Playback/recording through the PulseAudio sound server or the HDMI option. The device is still paired, just doesn’t seem to be recognized. Under nano .asoundrc do I put everything you have in blue, including the statements that start with #?
