Bluray Playback?
Hello
I am attempting to play back some blurays and am having some issues with encryption. Ive downloaded a couple of different KEYDB.cfg files as per the post:
And an updated KEYDB.cfg file from 12/12/2019 from here:
http://fvonline-db.bplaced.net/
Which has worked for some of my blurays but not for others.
I have also run dvdfab passkey and FindVUK on my PC to add the key manually (it appeared to already exist) with no joy.
If I already have the correct information for a particular disc why does kodi say its still encrypted?
Does it just depend on the type of encryption as to whether or not kodi can play it?
Would symlinking the libmmbd.so.0 from makemkv for libbdplus and libaacs as per:
https://www.makemkv.com/forum/viewtopic.php?f=3&t=7009
And
https://forum.kodi.tv/showthread.php?tid=173474&page=9
Work any better do you think?
A debug log should show if the title cannot be decrypted.
2019-12-29 13:29:22.056 T:2472538848   ERROR: CDVDInputStreamBluray::Open - Media stream scrambled/encrypted with BD+
2019-12-29 13:29:22.056 T:2472538848   ERROR: CVideoPlayer::OpenInputStream - error opening [bluray://%2fmedia%2fDeadpool%2f/BDMV/PLAYLIST/00801.mpls]
2019-12-29 13:29:22.057 T:2472538848  NOTICE: CVideoPlayer::OnExit()
2019-12-29 13:29:22.073 T:4071555072  NOTICE: CVideoPlayer::CloseFile()
2019-12-29 13:29:22.118 T:4071555072  NOTICE: VideoPlayer: waiting for threads to exit
2019-12-29 13:29:22.118 T:4071555072  NOTICE: VideoPlayer: finished waiting
So BD+ cant be decrypted?
Hard to tell with such a small snippet.
Edit: looks like BD+ requires a virtual machine. See Blu-ray - ArchWiki. I’m not sure Kodi supports this.
I tried installing:
sudo apt-get install libaacs0 libbluray-bdj libbluray1
and
sudo apt-get install libbdplus-dev
Which seemed to stop the notification that the disc is encrypted but it still doesnt play.
Which is unfortunate :frowning:
I don’t think BD-J will work properly. There’s been some discussion about it, but I seem to recall there being a nasty memory leak which didn’t make it feasible.
So ive been reading about bluray keys and such and I have a query:
If I can play the bluray in VLC in windows using libaacs.dll and whatever keys I have in “AppData\Roaming\aacs” should I not also be able to play it in Kodi?
If it wont play in Kodi because its encrypted, is this to do with the version of libacss0?
Im just trying to understand the limitations for playing blurays in kodi.
You can play it back in Kodi if you copy the keys over. BD-J won’t work however
hmm thats what I thought. I have copied over the keydb.cfg from windows and when I try and play the bluray:
2019-12-30 13:55:33.837 T:4067704832   ERROR: GetDirectory - Error getting return
2019-12-30 13:55:33.838 T:4067704832   ERROR: CGUIMediaWindow::GetDirectory(return) failed
2019-12-30 13:55:57.632 T:4067704832  NOTICE: VideoPlayer::OpenFile: bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls
2019-12-30 13:55:59.425 T:2856493792   ERROR: CDVDInputStreamBluray::Open - Media stream scrambled/encrypted with AACS
2019-12-30 13:55:59.425 T:2856493792   ERROR: CVideoPlayer::OpenInputStream - error opening [bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls]
2019-12-30 13:55:59.425 T:2856493792  NOTICE: CVideoPlayer::OnExit()
2019-12-30 13:55:59.450 T:4067704832  NOTICE: CVideoPlayer::CloseFile()
2019-12-30 13:55:59.484 T:4067704832  NOTICE: VideoPlayer: waiting for threads to exit
2019-12-30 13:55:59.484 T:4067704832  NOTICE: VideoPlayer: finished waiting
So it detects the AACS encryption but then it doesnt play?
Hard to tell with just a snippet and no debug log.
So is it the bdplus encryption where it falls down?
2019-12-30 14:05:14.397 T:4067704832   DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
2019-12-30 14:05:14.446 T:2397377248   DEBUG: Thread waiting start, auto delete: false
2019-12-30 14:05:14.446 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:1408: libbluray version 1.0.2
2019-12-30 14:05:14.447 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:1435: BLURAY initialized!
2019-12-30 14:05:14.447 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR18   (MENU_LANG) 0xffffff -> 0x656e67
2019-12-30 14:05:14.447 T:2397377248   DEBUG: CBlurayCallback::Logger - disc.c:326: failed opening UDF image (null)
2019-12-30 14:05:14.447 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:79: AACS/Unit_Key_RO.inf found. Disc seems to be AACS protected.
2019-12-30 14:05:14.447 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:83: BDSVM/00000.svm found. Disc seems to be BD+ protected.
2019-12-30 14:05:14.449 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:109: Using libbdplus for BD+
2019-12-30 14:05:14.449 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:140: Loading libbdplus (0xbd8fc100)
2019-12-30 14:05:14.449 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:161: Loaded libbdplus (0xbd8fc100)
2019-12-30 14:05:14.450 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:105: Using libaacs for AACS
2019-12-30 14:05:14.450 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:129: Loading aacs library (0xc3716d40)
2019-12-30 14:05:14.450 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:140: Loaded libaacs (0xc3716d40)
2019-12-30 14:05:14.466 T:3729720032   DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Playlist.OnClear  - data: {"playlistid":1}
2019-12-30 14:05:14.467 T:3729720032   DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Playlist.OnAdd  - data: {"item":{"title":"","type":"movie"},"playlistid":1,"position":0}
2019-12-30 14:05:14.467 T:3780076256   DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Playlist.OnClear  - data: {"playlistid":1}
2019-12-30 14:05:14.467 T:3780076256   DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Playlist.OnAdd  - data: {"item":{"title":"","type":"movie"},"playlistid":1,"position":0}
2019-12-30 14:05:14.546 T:4067704832   DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-12-30 14:05:16.395 T:2397377248   DEBUG: CBlurayCallback::Logger - dec.c:202: Opened libaacs
2019-12-30 14:05:19.887 T:2397377248   DEBUG: CBlurayCallback::Logger - dec.c:217: BD+ initialization failed (no AACS ?)
2019-12-30 14:05:19.915 T:2397377248   DEBUG: CBlurayCallback::Logger - bdj.c:689: BD-J check: Failed to load JVM library
2019-12-30 14:05:19.915 T:2397377248   DEBUG: CBlurayCallback - Opening dir /media/The Martian/BDMV/META/DL
2019-12-30 14:05:19.916 T:2397377248   DEBUG: CBlurayCallback - Closed dir (0xbaae14a0)
2019-12-30 14:05:19.919 T:2397377248   DEBUG: CBlurayCallback::Logger - bdj.c:689: BD-J check: Failed to load JVM library
2019-12-30 14:05:19.920 T:2397377248   DEBUG: CBlurayCallback - Opening dir /media/The Martian/BDMV/PLAYLIST
2019-12-30 14:05:19.945 T:2397377248   DEBUG: CBlurayCallback - Closed dir (0x94152840)
2019-12-30 14:05:20.050 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:1552: BLURAY destroyed!
2019-12-30 14:05:20.050 T:2397377248   DEBUG: Thread waiting 2397377248 terminating
2019-12-30 14:05:20.063 T:4067704832   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-12-30 14:05:20.063 T:4067704832   DEBUG: ------ Window Init (DialogSelect.xml) ------
2019-12-30 14:05:21.466 T:4047500000   DEBUG: LIRC: - NEW 160 0 KEY_OK linux-input-layer (KEY_OK)
2019-12-30 14:05:21.470 T:4067704832   DEBUG: HandleKey: 11 (0x0b, obc244) pressed, action is Select
2019-12-30 14:05:21.685 T:4067704832   DEBUG: ------ Window Deinit (DialogSelect.xml) ------
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerCoreFactory::GetPlayers(bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls)
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
2019-12-30 14:05:21.687 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (VideoPlayer)
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: 50DX700_Series
2019-12-30 14:05:21.688 T:4067704832   DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
2019-12-30 14:05:21.692 T:4067704832   DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData
2019-12-30 14:05:21.692 T:4067704832  NOTICE: VideoPlayer::OpenFile: bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls
2019-12-30 14:05:21.692 T:4067704832   DEBUG: OnPlayBackStarted: CApplication::OnPlayBackStarted
2019-12-30 14:05:21.692 T:2397377248   DEBUG: Thread VideoPlayer start, auto delete: false
2019-12-30 14:05:21.693 T:2397377248  NOTICE: Creating InputStream
2019-12-30 14:05:21.695 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:1408: libbluray version 1.0.2
2019-12-30 14:05:21.695 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:1435: BLURAY initialized!
2019-12-30 14:05:21.695 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR20   (REGION) 0x2 -> 0x1
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR13   (PARENTAL) 0xff -> 0x63
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:422: bd_psr_write(): PSR31   0x30200 -> 0x130240
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR24   (3D_CAP) 0x0 -> 0xffffffff
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR16   (AUDIO_LANG) 0xffffff -> 0x656e67
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR17   (PG_AND_SUB_LANG) 0xffffff -> 0x656e67
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR18   (MENU_LANG) 0xffffff -> 0x656e67
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - register.c:420: bd_psr_write(): PSR19   (COUNTRY) 0xffff -> 0x656e
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - opening /media/The Martian
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - disc.c:326: failed opening UDF image (null)
2019-12-30 14:05:21.696 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:79: AACS/Unit_Key_RO.inf found. Disc seems to be AACS protected.
2019-12-30 14:05:21.697 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:83: BDSVM/00000.svm found. Disc seems to be BD+ protected.
2019-12-30 14:05:21.699 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:109: Using libbdplus for BD+
2019-12-30 14:05:21.699 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:140: Loading libbdplus (0xe5ed04a8)
2019-12-30 14:05:21.699 T:2397377248   DEBUG: CBlurayCallback::Logger - bdplus.c:161: Loaded libbdplus (0xe5ed04a8)
2019-12-30 14:05:21.702 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:105: Using libaacs for AACS
2019-12-30 14:05:21.702 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:129: Loading aacs library (0xe5e044d8)
2019-12-30 14:05:21.702 T:2397377248   DEBUG: CBlurayCallback::Logger - aacs.c:140: Loaded libaacs (0xe5e044d8)
2019-12-30 14:05:21.702 T:2561659616   DEBUG: Loading settings for bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls
2019-12-30 14:05:21.715 T:4067704832   DEBUG: CVideoGUIInfo::InitCurrentItem(bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls)
2019-12-30 14:05:21.754 T:4067704832   DEBUG: CPlayerGUIInfo::InitCurrentItem(bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls)
2019-12-30 14:05:21.766 T:4067701472   DEBUG: UPnP: Building didl for object 'bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls'
2019-12-30 14:05:21.782 T:3729720032   DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Info.OnChanged  - data: null
2019-12-30 14:05:21.782 T:3729720032   DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Player.OnPlay  - data: {"item":{"title":"Play main title: 800","type":"movie"},"player":{"playerid":1,"speed":1}}
2019-12-30 14:05:21.793 T:3780076256   DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Info.OnChanged  - data: null
2019-12-30 14:05:21.793 T:3780076256   DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnPlay  - data: {"item":{"title":"Play main title: 800","type":"movie"},"player":{"playerid":1,"speed":1}}
2019-12-30 14:05:21.859 T:4067704832   DEBUG: ------ Window Init (DialogBusy.xml) ------    2019-12-30 14:05:23.546 T:2397377248   DEBUG: CBlurayCallback::Logger - dec.c:202: Opened libaacs
2019-12-30 14:05:27.027 T:2397377248   DEBUG: CBlurayCallback::Logger - dec.c:217: BD+ initialization failed (no AACS ?)
2019-12-30 14:05:27.120 T:2397377248   DEBUG: CBlurayCallback::Logger - bdj.c:689: BD-J check: Failed to load JVM library
2019-12-30 14:05:27.120 T:2397377248   DEBUG: CBlurayCallback - Opening dir /media/The Martian/BDMV/META/DL
2019-12-30 14:05:27.121 T:2397377248   DEBUG: CBlurayCallback - Closed dir (0xf1e09a70)
2019-12-30 14:05:27.125 T:2397377248   DEBUG: CBlurayCallback::Logger - bdj.c:689: BD-J check: Failed to load JVM library
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:3115: PSR change: psr3 = 1
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:3115: PSR change: psr4 = 65535
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:3115: PSR change: psr0 = 1
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:3115: PSR change: psr1 = 255
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:3115: PSR change: psr2 = 268374015
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:3115: PSR change: psr14 = 65535
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - Disc name           : The Martian
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - First Play supported: 0
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - Top menu supported  : 0
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - HDMV titles         : 5
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - BD-J titles         : 86
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - BD-J handled        : 0
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - UNSUPPORTED titles  : 86
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - AACS detected       : 1
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - libaacs detected    : 1
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - AACS handled        : 1
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - BD+ detected        : 1
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - libbdplus detected  : 1
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - BD+ handled         : 0
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CDVDInputStreamBluray::Open - no menus (libmmbd, or profile 6 bdj)  : 0
2019-12-30 14:05:27.126 T:2397377248   ERROR: CDVDInputStreamBluray::Open - Media stream scrambled/encrypted with BD+
2019-12-30 14:05:27.126 T:2397377248   DEBUG: CVideoPlayer::OnDiscNavResult - libbluray the disc/file is encrypted and can't be played (DVDSTATE_NORMAL)
2019-12-30 14:05:27.126 T:2397377248   ERROR: CVideoPlayer::OpenInputStream - error opening [bluray://%2fmedia%2fThe%20Martian%2f/BDMV/PLAYLIST/00800.mpls]
2019-12-30 14:05:27.127 T:2397377248  NOTICE: CVideoPlayer::OnExit()
2019-12-30 14:05:27.127 T:2397377248   DEBUG: CBlurayCallback::Logger - bluray.c:1552: BLURAY destroyed!
2019-12-30 14:05:27.127 T:2397377248   DEBUG: Thread VideoPlayer 2397377248 terminating
Yes, it seems to be.
So even though VLC can play it with its own libraries and keys it cant be decrypted in Kodi?
Is there any option of compiling the VLC libraries for osmc?
We use libaacs, which is a VLC library from the stretch repo
You can recompile it and potentially enable BD+ support if there is a newer version available
I tried building libaacs from:
https://download.videolan.org/pub/videolan/libaacs/0.9.0/libaacs-0.9.0.tar.bz2
 cd /home/osmc/libaacs-0.9.0
 ./configure
make
sudo make install
Which appears to work but the same bluray doesnt play.
When I run:
ldconfig -v | grep libaacs
I get two entries for libaacs, is that normal?
libaacs.so.0 -> libaacs.so.0.5.1
libaacs.so.0 -> libaacs.so.0.6.0
Doesn’t look like Kodi is loading your version. Try set —prefix=/usr during configure
I re-ran ./configure with --prefix=/usr and now get three entries for “ldconfig -v | grep libaacs”:
But the bluray still doesnt play. I think it may be beyond my capabilities to get working, but thanks for your help anyway.
Seems like if its a fox bluray and/or has dolby atmos then it wont play in kodi, otherwise it seems to work (even with pretty new films, eg Venom/Aquaman works fine while Minority report which is much older, doesnt).
I was hoping it would be a bit more cut and dry, pre 2016 works, post 2016 might work. Oh well if it works in kodi i’ll use it to watch movies, otherwise if I need menus and/or it doesnt work i’ll use my proper bluray player.
Oh well at least i can use it to watch R1 DVD’s
EDIT ** whatever I have done appears to have broken dvd playback, HELP!
Hello
I was trying to get bluray playback working for some newer titles (which only works if kodi can decrypt them) but in so doing i seem to have broken DVD playback (which was working yesterday!)
Ive uploaded logs here:
https://pastebin.com/5iXiYK5m
Im hoping I can get my dvd playback, back!
It seems like the DVD is not getting mounted correctly?
1. 19-12-30 17:08:28.474 T:4066279424   DEBUG: CVideoGUIInfo::InitCurrentItem(/media/TWIN_PEAKS_GOLD_DISC_1/VIDEO_TS/VIDEO_TS.IFO)
2. 2019-12-30 17:08:28.478 T:3305181920   DEBUG: libdvdnav: Can't read name block. Probably not a DVD-ROM device.
3. 2019-12-30 17:08:28.478 T:3305181920   DEBUG: libdvdnav: vm: dvd_read_name failed
4. 2019-12-30 17:08:28.478 T:3305181920    INFO:   msg: libdvdnav: vm: DVD Title:
5. 2019-12-30 17:08:28.478 T:3305181920    INFO:   msg: libdvdnav: DVD disk reports itself with Region mask 0x00f60000. Regions:
6. 2019-12-30 17:08:28.479 T:3305181920    INFO:   msg:  1
7. 2019-12-30 17:08:28.479 T:3305181920    INFO:   msg:  4
8. 2019-12-30 17:08:28.479 T:3305181920   DEBUG:   msg:
Should I do a full reinstall of osmc from an SD card?
