Osmc-installer package is still broken, actually i have never seen its working on Fedora / CentOS systems. There are some weird dependencies like libjpeg8 and libpng12-0, and well fedora/centos dont offer those with those names.
Before i give up trying and installed OSMC under Windows, but now i couldnt use Windows so i have to compile that package again from src.rpm and now its seems atleast start well.
I wonder if someone really got it installed from that repo? I can submit working srpm package if someone wants, but unable to test it under OpenSUSE.
I am trying to fix this, but RPM packaging is not my strong point. I found in CentOS and RHEL that we want:
libtiff; libjpeg-turbo and libpng packages.
Have tried to resolve this for CentOS and RHEL. We are using Open Build Service and you can view our spec file here:
committed 10:08AM - 11 Jan 15 UTC
It’s missing the following packages:
libjpeg-turbo-devel.686 1.3.1-4.fc21
libtiff.i686 4.0.3-18.fc21
libpng.i686 2:1.6.10-3.fc21
I can test on Fedora 21 if a new RPM is available
paavon
25 February 2015 20:53
4
Oh f… i forgot to answer here and comment something but now its seems work fine atleast for me. No need anymore compile it myself! Great job guys!
Problem solved, case closed.
Hi, this problem is still there, at least in my Fedora 22 64bit box.
After executing osmcinstaller i got a white empty window and those errors:
libpng warning: iCCP: known incorrect sRGB profile
X Error: BadAccess (attempt to access private resource denied) 10
Extension: 130 (MIT-SHM)
Minor opcode: 1 (X_ShmAttach)
Resource id: 0xd6
X Error: BadShmSeg (invalid shared segment parameter) 128
Minor opcode: 5 (X_ShmCreatePixmap)
Resource id: 0xd6
X Error: BadDrawable (invalid Pixmap or Window parameter) 9
Major opcode: 62 (X_CopyArea)
Resource id: 0x5800011
@sam_nazarko
I have the same problem that flashback. Any idea to resolve it ?
Thanks for the answer.
Dan
Unfortunately I don’t use Fedora or CentOS, so I’m not sure how to resolve this issue
This problem is still present in Fedora 23 / 64bits.
Same errors. Anybody figured this out?
flashback:
X Error: BadAccess
Note to self: after installing the osmc-installer package in fedora, run it with:
QT_X11_NO_MITSHM=1 /usr/share/osmc/qt_host_installer
Since this issue is still there, I think it might be worthwhile adding my 2 cents here.
Based on htpcero’s response, I instead edited the file /usr/share/osmc/osmcinstaller. It’s a shell script. Go to the following line:
cmd="$dir/qt_host_installer"
and change it to look like this:
`cmd="QT_X11_NO_MITSHM=1 $dir/qt_host_installer"`
Once done, you can forget about it. Simply use the command “osmcinstaller” on the command line as expected.
