Can anyone suggest/provide a Crystalubuntu 2 Mirror?
@Soli Are you referring to this?
http://chewitt.openelec.tv/appletv/
I have already tested it. The only problem I have found so far is that the AirPlay service is not working at all, since my iOS devices doesn’t enable the Airplay output while playing any media content… any clue to fix it?
To be honest, I haven’t tried the airplay function on OE. The log should probably give you the answer. I suspect it might be missing a required library, which would be an easy fix.
Avahi needs to be re-enabled to get Airplay to work.
I’m trying to downgrade to to 14.2 from 15 but the link to wrxtasy’s script instructions is broken. Does anyone know where I can find the instructions?
