Can not click Done for pin for auth.key-file
Hello guys,
Trying to set up my OSMC with Netflix
I use Raspberry PI 3B+
And I use this version of the OSMC:
2021.12-1
Now I try to install Netflix, following this guide:
Unfortunately it looks like I need to use the auth.key to login-method.
But when I try to enter the PIN for the auth.key.file I get no chance to press Done, or Enter from my remote keyboard, nothing happens.
I have regenerate the auth.key-file twice (with different PIN of course) but the same happens, no chance to proceed it seems.
I will try to see if I can show you a “screen dump” of what it looks like, see attached image.
Best regards
Fredrik
I think this may be related to an issue with the current skin. Please try our staging skin, details can be found here:
Thanks Tom.
Hello,
When I followed your instructions it worked press the Done option.
How ever, when proceed the auth-key file option did not work, BUT the regular email/password-login started to work.
Thanks a lot!
Best regards
Fredrik
