You MUST provide logs! The screenshot ONLY indicates that a problem has occurred, not WHAT problem has occurred. If you can get into command line, simply issue grab-logs -A
and provide the URL that results! DETAILS are very important!
ill give it a try tomorrow! i have no more time today, hopefully this will work as last time it wouldntā¦
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:cSyzLY5BK7XVxQqatjRJJM4ykgZIacJClUsPxwhv2sA.
Please contact your system administrator.
Add correct host key in /Users/Josh/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /Users/Josh/.ssh/known_hosts:1
ECDSA host key for 192.168.000.005 has changed and you have requested strict checking.
Host key verification failed.
this is what comes up
vi +1d +wq ~/.ssh/known_hosts
on your computer
or
ssh-keygen -R "ip of osmc installation"
For starters. Here is my logs (I think kernel will the one one might find reasons in). http://paste.osmc.io/jilopapuqu
As for Mediainfo, not sure what you need. Below is a full cut/paste from an example file that does not work.
General
Complete name : /Volumes/Multimedia/Video/Film/The Second Best Exotic Marigold Hotel (2015) 1080p.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 2.34 GiB
Duration : 2h 2mn
Overall bit rate : 2 731 Kbps
Movie name : The.Second.Best.Exotic.Marigold.Hotel.2015.1080p.BluRay.H264.AAC-RARBG
Encoded date : UTC 1904-01-01 00:00:00
Tagged date : UTC 1904-01-01 00:00:00
Writing application : Lavf56.16.102
Comment : The.Second.Best.Exotic.Marigold.Hotel.2015.1080p.BluRay.H264.AAC-RARBG
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 2mn
Bit rate : 2 500 Kbps
Width : 1 920 pixels
Height : 808 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.067
Stream size : 2.14 GiB (92%)
Writing library : x264 core 144 r2525M 40bb568
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=32 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=2500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=3:1.00
Menus : 3
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 2mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Channel(s)_Original : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Stream size : 197 MiB (8%)
Language : English
Default : Yes
Alternate group : 1
Menus : 3
Typical problem scenario is video shows up but freezes directly (often with a partly decoded frame), audio plays (sometimes for as long as 10 seconds) then everything is as rest⦠At this point there is nothing to do but power cycle (if one does not have a terminal at hand, which the wife and kids seldom doā¦)
Please produce a small sample to replicate the problem and upload it so I can investigate
there is a pastebin for long stuff like that might come in handy in the future.
anyone that can or will look at these logs? can you give me any advice?
thanks
Unpacking atv-image-4.2.3-7-osmc (7) ...
dpkg: error processing archive /var/cache/apt/archives/atv-image-4.2.3-7-osmc_7_i386.deb (--unpack):
unable to clean up mess surrounding `./boot/config-4.2.3-7-osmc' before installing another version: Read-only file system
Looks like your file system has been corrupted, likely due to unclean shutdowns. Youāll need to fsck the partition to get it back to a usable state.
great, the only way i know how to shut this down or get it out of freezes is to hold down the menu button and the bottom down button in order to get it to resetā¦
how do u fsck the partition? or is it just another reinstall?
plus this goes along with the image i posted above? it just stopped installing and flashed the above image,
thanks!
No problem hope you can sort it out
osmc@osmc:~$ fsck /dev/sda1
fsck from util-linux 2.25.2
** /dev/sda1
** Checking HFS Plus volume.
** Checking Extents Overflow file.
** Checking Catalog file.
** Checking Catalog hierarchy.
** Checking volume bitmap.
** Checking volume information.
** The volume untitled appears to be OK.
it all seems to be ok?
Indeed it does
so i guess it maybe the update again? not really sure? as my disc is fine, not sure what next steps should be in order to get file system back to normal without having to redo the install again and thus erase everything ive put in place
using sudo fdisk -l this is whats returned, and i dont know how to unmount 2nd partition in order to fsck it? it is part of the same hard drive just seperate partition, and wont fsck
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/sda: 149.1 GiB, 160041885696 bytes, 312581808 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 43433D21-6446-4729-BFAE-6BAEC1854012
Device Start End Sectors Size Type
/dev/sda1 40 500000 499961 244.1M Apple TV recovery
/dev/sda2 503808 312580095 312076288 148.8G Microsoft basic data
try it from terminal
sudo apt-get update && sudo apt-get dist-upgrade -y
and if it fails
sudo apt-get install -f
will do!
first command line used returned this at the bottom:
Calculating upgrade⦠The following package was automatically installed and is no longer required:
atv-image-4.2.3-6-osmc
Use āapt-get autoremoveā to remove it.
Done
apt-utils atv-kernel-osmc atv-userland-osmc base-files-osmc bind9-host ca-certificates exfat-fuse exfat-utils i386-connman-osmc
i386-remote-osmc i386-splash-osmc libbind9-90 libdns100 libisc95 libisccc90 libisccfg90 liblwres90 locales mediacenter-addon-osmc
mediacenter-skin-osmc passwd tzdata
22 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
21 not fully installed or removed.
Need to get 0 B/44.6 MB of archives.
After this operation, 42.9 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
atv-image-4.2.3-7-osmc atv-kernel-osmc atv-userland-osmc base-files-osmc i386-splash-osmc i386-connman-osmc i386-remote-osmc
mediacenter-addon-osmc mediacenter-skin-osmc
E: There are problems and -y was used without --force-yes
osmc@osmc:~$
so at the end instead of using -y i used --force-y and it actually asked me if i wanted to install without verification, i typed y
i386-splash-osmc i386-connman-osmc i386-remote-osmc mediacenter-addon-osmc
Install these packages without verification? [y/N] y
Preconfiguring packages ā¦
and we will see what happens!
it says updated, ill reboot and see if it worked!!
I WONDER WHY? it could not be verified on my machine???
how do u type in for it to reboot from command line?
