If I try to establish a static WLAN connection in “My OSMC/Network/Wireless” on my new Vero V, my ‘FritzBOX! 6490 Cable (5 GHz)’ is found just fine, but after entering my password, I always get an IP address assigned like for instance
IP: 169.254.96.210 and Subnet mask is always: 255.255.0. All other positions are empty. So, the internet connection try fails.
The first six numbers of the IP I get are always the same, the rest vary. If I try to change IP-address, subnet mask, standard gateway and primary DNS to static values according to my router/lokal network, those entered values are set back to the ones shown above instantly.
I am using IP addresses in my LAN like 192.168.1.1 (Standard-Gateway/Fritzbox-Router), 192.168.1.2 … 192.168.1.10 PCs and other devices, Subnet Mask 255.255.255.0 and 192.168.1.1 for my Primary DNS. (Secondary DNS I leave empty).
All my wlan connections are created with: “Wi-Fi 5, 80 MHz, WPA2, 2 x 2”.
How can I get a working WLAN, if my entered values cannot be recognized and established?
BTW, the ethernet cable LAN connection works fine, but needed quiete a few tries to establish, and I think I had to prepare a LAN connection in the Fritzbox with the appropiate MAC-Address of my Vero V, before I could successfully made a connection to the internet.
Things are not quite as stable as they should be. ![]()
