Hello,
Only recently discovered OSMC; tried it first on an “rPi 2” and was very impressed, so bought a “Vero 2” which arrived this-morning.
I’ve noticed some … interesting … differences; I’ll mention them at the end in case anyone is interested.
But it’s generally best to keep a post to 1 single subject/problem/suggestion/…, so the main query I have is this:
I simply cannot seem to get 3D to work. At all!
OK, on the “rPi”, I didn’t manage to playback 3D content either. I assumed that was because, as it was just an experiment, I didn’t bother with the hardware decode licenses, so I’d imagine it would struggle with software decoding that bandwidth of data.
However I did manage, just playing around, to set the menus to 3D mode. That worked fine; the TV (an LG) detected 3D content and switched into 3D mode; just what I’d expect.
Not, however, on the “Vero 2”. Same 3D TV (as in exactly the same TV, not just the same model - this was plugged into the end of the same HDMI cable I’d used with the rPi …). It seems as though the “Vero 2” has at least detected that there’s a 3D TV there, because I can change the menu options to 3D versions. However neither 3D mode works - the display changes so I can see (for example) the SBS images, but the TV does not detect any 3D content.
I’ve set the frame rate to auto, and looked through the forums (fora?) for other suggestions. I did find some suggested options, which aren’t present in the menus on my unit - either because they were older posts and things have changed, and/or because there’s menu differences between (for example) the “rPi” and a “Vero 2”. IIRC (it was only 3 days ago, but that was 3 days ago!
) the auto-frame rate (and “Use full HD for 3D modes”, which doesn’t seem to be present as an option on the “Vero 2”?) that I changed on the “rPi” to get 3D being recognised by the TV.
Oh, and I’ve also tried playing some 3D Blu-Ray ISO rips (made with “AnyDVD HD”) - they play fine, but again, no 3D (at least it doesn’t even try and just displays the left-eye - 2D - track).
Various posts mentioned “[/opt/vc/bin/]tvservice” as a useful diagnostic to try, to see what was reported back and ultimately negotiated as the best mode. Unfortunately, I don’t seem to have “/opt/vc/bin/”, let alone a “tvservice” command in there (or anywhere else - I checked …). So that’s not a lot of help …
The KODI log reports this:
... 12:52:28 T:3031810048 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic 12:52:28 T:3031810048 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 30.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 25.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 24.000000 Hz 12:52:28 T:3031810048 NOTICE: Found resolution 1920 x 1080 for display 0 with 4096 x 2160 @ 24.000000 Hz 12:52:28 T:3031810048 NOTICE: Found (1920x1080@50.000000) at 23, setting to RES_DESKTOP at 16 ...
Which isn’t encouraging, I don’t think anyway, as I see no mention of 3D modes there. But then I don’t know what I’d see in the logs if there were 3D modes detected - other than the “Using EGL Implementation …” line (and, of course, the time-stamps …) it looks pretty much identical to the same log from the “rPi”. So no help there either …
So any hints as to why OSMC on a “Vero 2” might not correctly detecting/driving/… the 3D capability of the TV when the same version of OSMC on an “rPi” apparently does? Actually, scrap that - my days of academic interest in the source of these sorts of issues are long gone - I just want to resolve it!
Thanks,
Tris (THEM).
Ps. “rPi” v.s. “Vero 2” differences.
- Updates. The “rPi” installation image seems to have more (for example) add-ons listed out-of-the-box. I don’t fiddle with much, but I do like to have weather up by the clock; on the “rPi” version, that was trivial; on the “Vero 2” it was an hour or so before any add-ons appeared to be available (they’ve literally just appeared and the box has been up for, well, a couple of hours now, thinking about it …).
- Updates. I told the “Vero 2” to update itself. It did. I rebooted. It crashed. Nice kernel stack dump all down the left-hand side of the screen. Oops … OK, so I BRS’ed it and back it came, absolutely fine, no problems since. But there was something about the update from “Out of the box from an item delivered today” to “Current version” that it really didn’t seem to like …
- Hardware. Nice touch - I always appreciate it when manufacturers put the MAC address on a sticker. Unfortunately it wasn’t the correct MAC address. The device has an address of 00:11:22:33:44:55 (which, needless to say, does not match what it says on the sticker …), so that caused some slight confusion and, more importantly, means if they’re all shipped like that, people won’t be able to run more than one on the same network …
) - I’ll update you whenever it’s got here!
