After a recent update I can no longer login to my Pi using SSH from other computers
on the same network. The Pi is pingable, and other computers are wired (not wireless).
If I reboot I get a sad face alternating between the sad face and two lines of text that
say segmentation fault. ( I cant do anything except remove power cord and reboot).
When OSMC does start I still cant use SSH.
I think the update is just coincidence, there have been two power cuts and wonder if the micro SD card ext4 partition has become corrupted.
Luckily I can remove the sd card and run a fsck.ext4 on the partition, but I’ll wait for advice from the forum mods first.
What Is strange is that I can access the pi via sshfs and have access to the mounted fie system.
Attempting SSH from another linux computer via the console attempts to login and
then returns me to the command prompt. I can post std out from ssh -vvv if anyone
wants to see .
Thanks in advance
I suggest you press ESC while Kodi restarts to drop down to the local console to check the system.
Surely it can be filesystem corruption either caused by the power cuts or even worse a failing SD Card. I suggest you first go to the consle to get some logs via grab-logs -A than make a backup and check you SD Card
Hi Fzinken,
Thanks for a super fast reply <4 mins!!
OK, my RPi does not have a keyboard so I used the one from my PC. Pressing ESC showed a few lines but returned to a blue splash screen with OSMC logo.
I tried an alternate console, ctrl-alt-F2 and for a brief time got a login prompt but as soon as kodi booted the console was not available
Still cant access via SSH so could not run grab-logs -A However used the TV remote
and went to OSMC settings and found log utility. Have uploaded all logs to
pastebin:
Ok, my suggestion is to get Kodi stable first. So take out the SD Card and plug into PC. Assuming you have Linux OS (if not boot from a live CD) ryou should see the second partition (ext4). On that one move the /home/osmc/.kodi folder to /home/osmc/.kodi_backup.
Unmount the SD Card and plug it back into the Pi. It should start Kodi normally.
You then can try to go to the console again.
Hi Fzinken,
That did it! have ssh access again and kodi starts. I think it will probably be better to reload
my kodi plugins again then copy from .kodi backup which was 586M
Not sure if this is related but
sudo apt-get update is throwing some errors:
osmc@osmc:/var/lib/apt/lists$ sudo apt-get update
Ign:2 http://ftp.debian.org/debian stretch InRelease
Hit:3 http://security.debian.org stretch/updates InRelease
Hit:4 http://ftp.debian.org/debian stretch-updates InRelease
Hit:5 http://ftp.debian.org/debian stretch Release
Hit:1 http://ftp.fau.de/osmc/osmc/apt stretch InRelease
Reading package lists… Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/ftp.debian.org_debian_dists_stretch_main_i18n_Translation-en
E: The package lists or status file could not be parsed or opened.
Getting rid of ~/.kodi has saved a lot of extra space (not that I was running out)
and it was the first time I gained SSH access.
Later I will run a full fsck on the partition to check, for now I feel it has been one of the addons or perhaps the unclean shutdown when there was a power cut. My Sandisk micro SD card has a 10 year warranty and although I’ve heard many times of SD card corruption, Ive been fortunate not to experience this myself.
OK, my previous post of No SSH access was fixed when I deleted ~/.kodi and rebooted.
My OSMC version was January.
After a manual update my OSMC version changed to February but cant load the March update the message on TV screen was
“Update Error- Please Report to the Forum”
The problem I have is I cant gain SSH access to my OSMC Raspberry Pi Model 2 using ethernet
I have removed my sdcard and ran a fsck against the ext4 partition it has reported clean
I then forced a check:
sudo fsck.ext4 -f /dev/sdb2
where sdb2 was the ext4 partition on my SD card. Again pass1 and pass2 clean fragmentatuin 0,2%
In the past Ive had all sorts of rubbish and interfaces and apache2, php that I dont need now, I’ve started clean by deleting .kodi but still cant get ssh access. I even tried ed25519
but still cant gain access.
On reboot I tried pressing Esc from attached USB keyboard but still cant gain access.
I have installed sshfs and can mount the full / filesystem on my linux labtop, this may be
one way of deleteing a file or plugin if it can be fixed.
Am I looking at a reload or any way to fix this?
Thanks in advance
(OSMC appears to work ok just cant access via SSH and I use crontab and mpc/mpd and
webiopi http://webiopi.trouch.com/ for some small home control)
Hi Fzinken,
Started a new thread as I marked last one closed and a different message (you can merge
threads if you want).
Ok, so after exit, then Esc TTY1 allows me to login with username and password (both osmc).
There is a brief message, then screen returns to TTY2 and brief message and back to TTY3, after TTY6 it returns to Kodi screen on TV.
The brief message is almost too fast to read but think it is this:
Linux osmc 4.14.15-5-osmc #1 SMP PREEMPT Sun Mar 4 08:39:02 UTC 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Mar 8 13:18:01 201
The above is also the same message if I try to access from SSH onsame network from another linux computer.
Should i be logging in with different credentials or is there anything else I can try?
Maybe considering the history try to plug the SD card into the PC and move the .kodi folder to .kodi_backup.
If that makes it behave normal you know that your kodi config is the issue.
If problem persist afterwards than you can move back your .kodi_backup and we need to investigate other possibilities.
I’m using:
OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.10, OpenSSL 1.0.1f 6 Jan 2014
that’s from Mint 17.3 SSH works to my other RPi running Debian Jessie
If I increase the verbosity on SSH:
ssh -vvv osmc@sofia
debug1: kex: client->server aes128-ctr hmac-sha1-etm@openssh.com none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA 50:14:d6:21:40:8b:de:8a:11:29:a8:3c:eb:33:ca:95
debug1: Host 'sofia' is known and matches the ECDSA host key.
debug1: Found key in /home/anc/.ssh/known_hosts:1
debug1: ssh_ecdsa_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /home/anc/.ssh/id_rsa
debug1: Trying private key: /home/anc/.ssh/id_dsa
debug1: Trying private key: /home/anc/.ssh/id_ecdsa
debug1: Trying private key: /home/anc/.ssh/id_ed25519
debug1: Next authentication method: password
osmc@sofia's password:
debug1: Authentication succeeded (password).
Authenticated to sofia ([192.168.254.8]:22).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: Sending environment.
debug1: Sending env LANG = en_GB.UTF-8
Last login: Thu Mar 8 20:04:20 2018 from 192.168.254.6
debug1: client_input_channel_req: channel 0 rtype exit-signal reply 0
debug1: client_input_channel_req: channel 0 rtype eow@openssh.com reply 0
debug1: channel 0: free: client-session, nchannels 1
Connection to sofia closed.
Transferred: sent 2824, received 3080 bytes, in 0.4 seconds
Bytes per second: sent 7878.7, received 8593.0
debug1: Exit status -1
A lot of output but predomintly the lines:
match authentication. I’ve even deleted both ~/.ssh keys on client (Linux Mate) and
deleted from server OSMC using sshfs but still problem persists.
Have also tried using remote control from OSMC settings, services disabling SSH access and then re-enabling it, still the same.
I have a feeling that due to past history my OSMC its ready for a card format and reload.
It’s not clear what the problem is but you mentioned you’re using -vvv debug level. However, we only see debug1 messages. We should also be seeing debug2 and debug3 messages.
I’d say your SSH client isn’t necessarily off the hook.
I’ve just rebooted into Manjaro Linux OpenSSH v7.1 and still the same problem with OSMC.
Im sure it will be down to my previous history of installing too many unwanted packages.
I wish i’d have runu
to have made a copy of the osmc directory structure when things were normal.
Still all working about from SSH but i cant understand why sshfs still works.
Commnds are
sshfs osmc@sofia:/mnt/backup backup
where /mnt/backup is my external hard drive partition connected to the Pi and backup is just the mount directory on my local machine. I have disabled root login in /etc/ssh/sshd_config as just limited to osmc account
OK, Ive decided to reinstall.
This problem is one I’ve caused, not a fault of OSMC or a bad update. Forum time is valuable
and I’ve had many replies already.
I think re-installation should just be a matter of a quick fsck or rm -rf on the ext4 partition, copy the install image and execute it. I’ve backed up all my own files. I’ll make a copy of my codec license keys from /boot partition.
