Sometime earlier this year I did a fresh install of OSMC.
To my surprise, and glee, I found an option to pause/stop playback, rather than just standby/shutdown when I put my TV on standby through the magic of CEC.
However, after updating, the option is no longer available.
Is there anything I can do to get it back?
I use my TVs shutdown timer function daily, and having to pull the plug on my pi all the time is tiresome.
Settings level is Expert.
I can access the CEC menu.
But the only available actions for OSMC when the TV goes on standby are “Sleep” and “Shut down”.
Actions such as “Pause Playback” and “Stop Playback” were previously available.
If you are using an option that either attempts to shutdown or standby the pi, you are doing it wrong. These should be disabled since those options are not supported on pi and result in requiring you to power pull. You will eventually end up with a corrupt sdcard that will require a complete reinstall if you continue to pull power like this.
But you can disable the shutdown/standby options! This allows the pi to run 24/7 right? I don’t understand why it’s such a hairy deal if the media continues to play after the TV is turned off. It’s certainly the lesser of two evils here…
in one of the recent updates of kodi it was possible to select to pause playback on tv power off. This option in the CEC settings is gone now. Could you please integrate it again or is this something i need to address to the kodi developers?
