Prior to upgrade of Vizio firmware (out of the box) CEC was working albeit only if the TV was running prior to booting RPi / OSMC.
I don’t recall the previous version number, but 3.23.xx sounds about right.
I know OSMC is a bit old, but I want to maintain the Jessie train as I have a Retropie install and it will not setup/install on Stretch. As long as there have been no changes to the CEC Library there shouldn’t be a difference.
I figured what the hell, I can change some 1s to 4s and see what happens.
Everything seems to be working now. I can control the menus, it even persists control after power cycling the TV and changing inputs where previously that was an issue.
I’m not sure what device_type “4” is vs “1” but it seems to have solved my issue.
Edit: Looks like device type 4 is “Playback Device” (Source)
No, I have just the OSMC device. I have 2 other devices connected via HDMI: Xbox 360 & Nintendo Switch. Neither are CEC compatible as far as I know. Also, neither were powered on.
Interesting. My first experience with a Vizio device but the price point was right.
The customer service was HORRIBLE btw, I tried to get a rollback binary for the firmware… It was like I had 3 heads and was speaking Mandarin. But I also get rubbish service from Samsung so… at least I saved a few bucks?
Anyway this seems to be the ticket for the fix, glad I stumbled on it. I was about to take the the screen back and try a HiSense panel… which I really didn’t want.
I have a P75, replaced twice… (first time because of the backlight had a “dead” column and the second time because the TV was rebooting on its own). Having said that, the image quality is truly outstanding.
Looks like RetroPie has made some stretch updates. I’m going to try updating my image this weekend. Would be a good time to do any CEC testing if you still want me to try something.
Hey Sam, thanks for the suggestion, but the fix in the thread referenced was ultimately a new hdmi cable. The Samsung post I found fixed my issue I thought you wanted me to test something else out.
