Change subtitles default colors
Hello,
Due to my display configuration I notice that default subtitles colors are too bright. I would like to know if it is possible to edit those colors to set them less bright or mate.
Do you know if this can be done?
You should try using the forum search.
I don’t think that replies my question. I know how to use subtitles options in expert mode in kodi but I don’t want to use the default colors, I want to know if it is possible to change the options available. For example, I would like to set the exact color and don’t use the 8 options kodi provides by default.
Sorry If I was not clear enough
If that is your question, then you would probably want to ask Kodi forums for that answer.
https://forum.kodi.tv/forumdisplay.php?fid=166
Using our forum search does also return info specific to your issue as well.
https://discourse.osmc.tv/search?q=bright%20subtitles
