Hallo !
I did clear installation. After change to my favorite skin confluence. But after restart skin change back to default and lost some setting.
Raspberry Pi3 and osmc ver. 20170322.
I am very unhappy from thist situation, because now i have to use another system. Because osmc is impossible to normalluse.
It is a known problem that is being worked on, you would have discovered this if you had used the excellent search function.
Hi there, on my Raspberry Pi3 I am running the latest Krypton test build. Everytime I change something under skin settings it gets set to default after a reboot. I just found out that if a make a change, shutdown the Pi & power it back up the changes are stored? Is anyone else experiencing this problem?
For me is a general problem. For me it is doee not matter if Bluetooth working or not. I want my skin back !!!
The fix for this problem will soon be released publicly. You can upgrade now to the latest development build if you can’t wait any longer. See this thread for more info on how to do this.
