Compatibility for DAC - Topping D50s?
I plan to buy this device to replace my old NuForce uDac2. Anybody try it ? Is it working out of the box ?
Thx,
It seems to need special drivers to get the best out of the XMOS chip. It looks like those are only available for Windows. See also here.
Should work without issue, except you might need an external usb hub for power. Normally windows drivers are just needed for ASIO compatibility, which you don’t need for Linux/Mac.
Ok thx for the reply ! I plan to use an external power if I get some issues…
