Trying to unravel this mystery further…
I am in over my head, but, I am determined to work through this. As I’m sure you can tell I was never a network expert and since it has been a long time, for many things I am starting over.
I have a desktop PC which has two monitors. PC is a desktop so I can not move around the house with it. So, for this troubleshooting, I have the Vero4k+ connected to one of the two monitors (whichever Vero4k unit I’m working on, but only one at a time; I have them labelled to keep track of which is which). The PC is connected to the other monitor. I can hook up to the network, more than one Vero4k at a time but I would have to go back & forth between rooms, or, I could connect them to all to the ethernet switch next to the desktop, and swap the HDMI cables back & forth as needed.
Yesterday, after the above post, I plugged back in the ‘non-working’ unit, and then at the black screen, I got distracted for some hours. I came back much later, and it had booted up?! However, it does not display movies or tv shows, nor even list those ‘headings’ on the main menu. The other two units do.
Following is what I can determine so far:
first just remove the SQL section
I don’t know how to do this. Browsing around, I found under MyOSMC–>NETWORK–>MySQL, the following:
- Enable MySQL Video Database = Square Box is ‘lighted’ = ENABLED
- Enable MySQL MusicDB = Square Box is ‘lighted’ = ENABLED
Underneath both of those are (nearly) the same thing:
- Name: MyVideos …or… MyMusic
- IP Address: the old static IP address; as noted above I already made a reservation for the QNAP, in the eero router; the QNAP reservation = static address is 192.168.1.108
- Port: 3306
- User: kodi
- Pass: **** (literally it is 4 asterisks; selecting that item, I am shown a keyboard and again 4 asterisks; I do not know/remember this password)
Below those two columns, it also shows
- Import Watched State: ENABLED
- Import Resume Points: ENABLED
I assume I should disable both of these and reboot. I will try that.
Further browsing the area, under WIRED…
- Enable Adapter = DISABLED
Attempting to enable it, it sits there for a few seconds and then turns itself back off.
Below that,
- Automatically configure the network toggle = GREYED OUT
Far below that,
- Wait for Network = ENABLED
The next section, WIRELESS …
- Enable Adapter = ENABLED (It appears to be successfully connected to my wireless network.)
- Status: Connected
BLUETOOTH = DISABLED
TETHERING …
- Hostpot SSID = osmc_wifi
- Hotspot passphrase = h0tsp0t0smc … and I think those are three zeros but not certain
- Ethernet_to_Wifi = ENABLED
- Wifi_to_Ethernet = DISABLED
- Do not connect this device to a wired network with a DHCP server
… with the mouse I can browse to the word ENABLE and I cannot browse to the word DISABLE. Given that the ethernet does not seem to be working, to be candid this is confusing. Because ‘disable’ is greyed out, is it already disabled? If I were to click on ENABLE, would it then be enabled? And if enabled, does that mean it would then be blocking connections to a wired network, meaning that function would be disabled so to speak? So, enabling it, disables it?
look at the DHCP Lease List
I also do not know how to do this.
Looking on the QNAP, I have two ways to examine the folders on the hard drive: Windows File Explorer on the PC, or, “FileStation” on the QNAP (accessed via the QNAP via browser, and logging in). Using the FileStation app, I can see some hidden folders that I cannot see via File Explorer. they all begin with a period. Anyways, I cannot find the above referenced MySQL libraries, neither as files nor as folders. I vaguely recall being taught another way to access ‘files’ and ‘folders’ (directories?) on the Vero4k’s, and on the QNAP.
The QNAP has an add-on, called phpMyAdmin. Clicking on that brings up a browser page to log in, but I don’t know that username & password. I tried user=kodi or user=root or user=admin, and PW=(lots of things, including blank, root, 1234, abcd, etc.) without success. The reason I mention this is, when it fails to log in, the message states: “Cannot log in to the mySQL server”.
I cannot find in the Vero4k settings, where to view or set the device’s network name/path. In SETTINGS → SYSTEM INFO …
- Storage: Filesystem = /dev/vero-nand/root, Size = 14G, 26% used
- Network: IP address: 192.168.11.22
- Hardware: Serial: 210d0400e9f97efc4a0ac42bb137657c
I have not yet tried to sort out why, in Windows 10 File Explorer, the initial ‘view’ of the Network shows nothing. However when I browse to the QNAP by typing in it’s path/address, \QNAP, then I can see all the folders except the hidden ones that start with " . " (a period).
On the Vero4k, SETTINGS → MEDIA → LIBRARY → VIDEOS …
I used to have 3 main folders of “videos”, two for Movies (Kids & Parents) and two for TV Shows (Kids & Parents). We no longer need the Kids side of things. Attempting to browse to any of them: Connection timed out, then Couldn’t connect to network server. Attempting ADD VIDEOS → BROWSE , I am presented with choices
- Home Folder (.kodi, .ssh, Backup, Movies, Music, Pictures, TV Shows) … the ‘media’ folders are all empty.
- Network File System (NFS) … doesn’t work; no response
- Root filesystem, has a right arrow out to the right (bin, boot, dev, etc, home, lib, lib64, lost+found, media, mnt, opt, proc, root, run, sbin, selinux, srv, sys, tmp, usr, var) … something about the folder “mnt” is vaguely familiar
- Video Playlists … empty
- Windows Network (SMB) … empty
- Zeroconf browser
Options within ZEROCONF:
- FTP File Sharing on Vero4Kx__ … The underscore/blank is actually “B”, which looks like what I would name a device, since this one is from the Bedroom. Back in Windows 10 File Explorer, attempting to manually type in the path \Vero4Kx__ and trying many variations, including “B”, all with no success, while this device was powered up & plugged in. Anyways, clicking on this it freezes for a few seconds but otherwise has no effect.
- Samba shares on Vero4KxB (SAMBA) … child folder = osmc
- VERO4KXB (SAMBA) … child folder, also = osmc
