Hi,i have my OSMC with a Dynamic DNS(using No-IP) here : raspiosmc.ddns.net
Is connected by WIFI,the problem is i dont know what to do for change it and have the connection by cable(if i disconnect the wifi and connect cable all die,using the same internal IP and DNSs)
If you change medium (wifi -> cable) there will be a change in internal ip, so my guess is that your portforward in your router is still pointing to your wifi ip.
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
Hi ActionA my problem is that when i stream using web server Chorus at work is SO SLOW using wifi(in my house is fast,obvi),then i thought change to cable,but now the problem is,i access the web server(in my house) and is sloooooooow,why?
If you have port forwarding to both IPs in your router it will probably try to forward to the first one (100) and then wait for that to time out before trying to forward to the other one.
If you’re only ever going to use one or the other, just configure both wired and wifi interfaces to the same IP and have only 1 rule on your router.
Otherwise, pick one connectivity method and stick to it.
I tried using just cable(because i want more speed using the streaming of Chorus),then trying to connect to web server at house(raspiosmc.ddns.net:8080) or to vnc,to all is so slow.
If i use the internal ip(192.168.1.150:8080) all is fine
And with only wifi the problem is the slow streaming in chorus connecting at work(but i can access w/o problem).
Sometimes i used the two at same time but was a caos.
Whatever the disk sda4 is it is not responding. If it is an SD card, check to make sure it hasn’t gone corrupt, if it is a spinning disk check it has enough power.
