Recently, I have a problem.
I have been using transmission-daemon more than a year but recently when transmission is downloading media files, connman network service suddenly stops and I cannot connect via SSH. (But I made a automatic script that make starting connman again)
But I can still see GUI OSMC and it works well.
Do you have any expected issue about it?
Thanks.
I don’t suppose so. Post debug logs, please.
https://paste.osmc.tv/ipafunugof
There you go.
I guess the point is “cfg80211-error) wl_cfg80211_disconnect reason 3”.
See Wifi drop outs
I use Vero 4k and there isn’t iwconfig command.
What’s the command that is power management off?
Try: sudo apt-get install wireless-tools
I solved this problem with replacing 2.4Ghz wifi instead of 5Ghz one.
