Can someone recommend a remote connection software for Vero4? eg. Remote desktop, Teamviewer, VNC… etc. I need to control my Vero4K remotely from a Windows machine.
I have tried installing VNC the same way I have on my Raspberry Pi and it does not work.
Thank you
Check this thread
VNC would work for you.
@fzinken beat me to it.
If only only need to control Kodi remotely, you can do so using the built-in web interface (which is disabled by default). Everything else can be done via ssh.
That’s what I do. Remote-control through the Web-UI is best IMHO.
Thanks nabsltd. Why haven’t I thought of that before? I will give this a try.
