Customize Main Menu not working
Customize Main Menu is not working, the “change action” just freezes with only “back” working to return to the previous menu 90% of the time. Some times it works, but it then freezes on the next level.
It’s possibly timing related, it seems to kind of work if the time between opening the “change action” menu until pressing a button on the remote again is just right, but it’s extremely tricky to make this work for several levels.
This is a Vero 4k running OSMC 2021.12 19.3.
I’ve tried to move away the .kodi folder from ssh, but it doesn’t seem to make a difference.
Thanks a lot Tom_Doyle, that solved the problem! :+1:
