Second question, but unrelated enough from the other than hopefully it needs a new topic.
I have installed and configured deluged with a thin client which is working well, but I’d like to have it start on boot.
I’ve read around the 'web about upstart scripts, but have no idea where to begin. I would have thought a single line in the right config file would work.
I also tried enabling it as a service, which was suggested by somebody on IRC. Although the command didn’t error, deluged was not started automatically on next boot.
Our beloved /etc/inittab is no more. Instead, we have a /etc/systemd/system/ directory chock-full of symlinks to files in /usr/lib/systemd/system/. /usr/lib/systemd/system/ contains init scripts; to start a service at boot it must be linked to /etc/systemd/system/. The systemctl command does this for you when you enable a new service, like this example...
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
deluged
exit 0
But that doesn’t bring deluge up on boot either.
I must be missing something obvious!
edit: In fact, when I try to load deluged I get the following:
osmc@osmc:~$ deluged
osmc@osmc:~$ [ERROR ] 09:49:04 rpcserver:376 Couldn’t listen on any:58846: [Errno 98] Address already in use.
I’m guessing it must be because the rc.local file isn’t calling it for the user osmc?
