You currently can not. You will have to wait for the new testing being started via devel repository. As indicated here
The databases for both your Kodi 18 and Kodi 19 clients should work at the same time and not interfere with each other. Since they are completely separate they no longer share watched status and have to be updated separately, but they should still work, albeit a bit less useful than before the update. You could use Trakt to bring back some syncing between the clients in the meantime if this is an issue.
They do work, but I used Vero 4k to scan my libraries for changes and only have the mySQL db connection on Android, so now, when I add content, I donât see them on Android anymore.
Itâs not a big deal, I just thought I could use a nightly so it would run the same DB.
Still donât understand why there was nightly that worked on 19 but they donât anymore.
Thatâs the kind of answer I was expecting
ChillboOSMC Skinner
4.9 combined with the @gmc have not been cleared to run together. Additionally, the v19 nightly builds havenât been updated for quite some time.
So there was a nightly, but since 4.9 came out, nightlies are not compatible ![]()
Hi @fzinken
ls -lah /etc/samba/ | paste-log
https://paste.osmc.tv/ezovojofem
osmc@HTPC:~$ smbclient -L localhost
Unable to initialize messaging context
Enter WORKGROUP\osmcâs password:
Anonymous login successful
Sharename Type Comment
osmc Disk OSMC Home Directory
IPC$ IPC IPC Service (Samba 4.9.5-Debian)
INTENSO Disk Auto-mount Volume
disk3 Disk Auto-mount Volume
Ele Disk Auto-mount Volume
disk1 Disk Auto-mount Volume
OneTouch Disk Auto-mount Volume
Reconnecting with SMB1 for workgroup listing.
Server Comment
Workgroup Master
WORKGROUP HTPC
osmc@HTPC:~$ paste-log /etc/samba/smb.conf
https://paste.osmc.tv/qoritunafo
Well you managed to go to the old TESTING thread but nevermind letâs stay here.
So all your disks are shared via SMB.
Can you check again from your other machine?
Confirmed in other thread, all working after reboot.
