Device crashes when playing movies with Dolby TrueHD
Hey Sam,
quick question: Do you plan to investigate this further soon?
I just wanted to ask, because if this will take time for you to look into, I don’t need to check for new answers every couple hours :blush:
And because this issue is not a big problem for me, I don’t want to bother you with asking for any news everyday. So it would be nice if you could give me a short response.
You might already have discovered that you don’t need to check for answers. You will automatically get an email when someone post an answer to the thread :wink:
I’m looking in to it. It might be related to another issue. I’m not sure when I’ll have a concrete fix just yet.
To be honest, the real reason is that I thought Sam just didn’t see that I responded to his demand to upload 2 new logs and now this post would descent on the “latest posts” list and will never see the light of life again.
No — I’ve got a very complex way of tracking these issues so they don’t get lost.
Spoiler
I keep the tab open.
Hey Sam
any news?
Greets
It should be fixed now in today’s update.
@sam_nazarko
This post is very interesting as I went to check all clips on my reported post and they are also defaulted to the Dolby TrueHD. I am sure my fix will work for this issue as well.
Better the link the issues together for easy tracking.
Hey Sam,
I did the update, but the problem is still there.
Crash on 2nd skip.
Log
So @sniferx1 — the problem is only occurring for you on seeking?
@sam_nazarko it’s intermittent for me… I don’t know the crash is due to the seeking or due to my reported issue.
Sometimes it crashes without seeking… when I want to resume the movie from the crash point it sometimes hangs and then crash again…
Refer to my post for logs for all crashes / sad face.
@sam_nazarko
Just FYI this problem is still present for me
New logs (Crash at first skip)
Do you have a small video sample to reproduce the problem? I’m struggling to replicate here.
I just downloaded this test clip and it crashed at the 4th skip I think.
Then I played back the file again and it crashed at first skip.
Just a reminder: This does NOT happen when I use the OSMC remote. It only happens when using the progress bar of the Kore app:
And only with TrueHD/TrueHD Atmos clips, with TrueHD passthrough disabled.
Maybe the reason is, that the CPU load is too high for a brief moment, when the Vero has to transcode the TrueHD track and then it crashes.
Thanks, will investigate.
Does it crash when using the Yatse app as a controller? That would at least eliminate Kore as the problem.
Have you tried playing the same clip from local storage instead of over your network?
Yes, all attempts I made, except the 2 from today, were with direct connection over USB.
With Yatse the crashes do also occur.
If I see this correctly, this has obviously something to do with the TrueHD track being transcoded to AC3/LPCM.
Hey folks,
just wanted to tell you this problem still exists.
Opposed to my previous explanation, this seems to also happen when jumping to a chapter with the “up” and “down” key on the remote.
Logs
