Hello,
Today the Vero 4K+ prompted for a new update. I ran it, and it did not complete successfully. There was an error installing “vero3-device-osmc”. It seems this was a big update, because a lot of files were being installed. After the Vero rebooted, it came back up, but the TVHeadend server will not start anymore. When I try to reinstall the vero3-device-osmc file manually, I get an error too. Also, when I try to run update manually I get timeout when Vero connects to ftp.fau.de. There are no issues with connectivity to the internet, and ftp.fau.de is pingable. it seems there’s a problem with ftp.fau.de, but I am not completely sure about it. Additionally, I noticed that when Vero boots up, there are are failures for the RPC.
Can this issue/update be resolved without reinstalling the OSMC image? I don’t want to lose any data, especially for the TVHeadend.
Thank you.
smc@osmc:~$ sudo apt-get install --reinstall vero3-device.osmc
Reading package lists… Done
Building dependency tree
Note, selecting ‘vero3-device-osmc’ for regex ‘vero3-device.osmc’
Reinstallation of vero3-device-osmc is not possible, it cannot be downloaded.
You might want to run ‘apt --fix-broken install’ to correct these.
vero3-device-osmc : Depends: armv7-diskmount-osmc but it is not installable
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
osmc@osmc:~$ sudo apt-get update
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 Index of /debian buster InRelease
Hit:3 Index of /debian buster-updates InRelease
Err:4 Index of /osmc/osmc/apt buster InRelease
Could not connect to ftp.fau.de:80 (131.188.12.211), connection timed out
W: Failed to fetch http://apt.osmc.tv/dists/buster/InRelease Could not connect to ftp.fau.de:80 (131.188.12.211), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
osmc@osmc:~$ ping ftp.fau.de
PING ftp.fau.de (131.188.12.211): 56 data bytes
64 bytes from 131.188.12.211: seq=0 ttl=53 time=162.057 ms
64 bytes from 131.188.12.211: seq=1 ttl=53 time=164.181 ms
64 bytes from 131.188.12.211: seq=2 ttl=53 time=158.388 ms
— ftp.fau.de ping statistics —
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 158.388/161.542/164.181 ms
