DNR filter
I just SSH’d into the Vero and then did this:
sudo crontab -e
then added:
@reboot bash /opt/scripts/startup-user.sh
the script contains:
#!/bin/bash
PATH=/opt/sbin:/usr/sbin:/sbin:/opt/bin:/usr/bin:/bin
echo 1 | sudo tee /sys/module/di/parameters/bypass_all
That should do it, but I don’t think you need the PATH and since rc.local is run as root a simple
echo 1 > /sys/module/di/parameters/bypass_all would do it as well.
But with the next update bypass_all = 1 will be the default.
This is what I did for now, nice that the next update will solve it, now I at least am sure it will not happen again after a reboot.
It’s included in staging now and will be part of the next update (planned for Sunday)
