Vero 4K+ doesn’t recognize a 6TB HDD
This is the setup:
HDD bracket connected to the USB port of the Vero 4K+.
In the HDD bracket a WD blue 6TB (replacing a 2TB (in MRB)).
I reach the HDD on the Vero in Win10 using the Samba communication protocol.
This is what i’ve tried so far using MiniTool Partion Wizzard:
a 6TB newly created exFAT partition in GPT, wont work
a 1TB newly created exFAT partition in GPT, wont work
a 1TB newly created NTFS partition in GPT, wont work
a 1TB newly created NTFS partition in MBR, works
The common denominator seems to be “GPT”.
Here Can Vero 4k+ Access a 20TB HDD? fzinken refers to a topic with sort of the same question stating that OSMC isn’t limited and supports GPT and exFAT.
In another topic, though, I’ve found formatting the disk in OSMC could be an option. Me being a noob, i have no idea how to. But if this is the solution, is there a tutorial about it?
Thanks in advance
Yes, GPT is supported.
How is the drive powered?
I’d suggest posting logs so we can see what’s going on.
The harddrive is powered by its own powersupply. The previous 2TB (MBR) worked fine the same way.
I’ll search a “how to” of making a log.
reproduce the issue
I see only this:
Aug 03 17:16:49 osmc kernel: scsi 0:0:0:0: Direct-Access WD 60EZAZ External 1.75 PQ: 0 ANSI: 4
Aug 03 17:16:49 osmc kernel: sd 0:0:0:0: [sda] 3131110576 512-byte logical blocks: (1.60 TB/1.46 TiB)
Aug 03 17:16:49 osmc kernel: sd 0:0:0:0: [sda] Write Protect is off
Aug 03 17:16:49 osmc kernel: sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
Aug 03 17:16:49 osmc kernel: sd 0:0:0:0: [sda] No Caching mode page found
Aug 03 17:16:49 osmc kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Aug 03 17:16:49 osmc kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Doesn’t match either the 6TB or the 2TB drive. Which drive(s) do you have attached when booting?
FWIW, this is what I get with my GPT 4TB drive
[ 4.434682] scsi 0:0:0:0: Direct-Access Seagate Backup+ Hub BK D781 PQ: 0 ANSI: 6
[ 4.435989] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 4.436239] sd 0:0:0:0: [sda] 7814037167 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 4.440130] sd 0:0:0:0: [sda] Write Protect is off
[ 4.440141] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
[ 4.440591] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.441271] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 4.512447] sda: sda1 sda2 sda3
[ 4.513654] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 4.514978] sd 0:0:0:0: [sda] Attached SCSI disk
and
Disk /dev/sda: 3.64 TiB, 4000787029504 bytes, 7814037167 sectors
Disk model: Backup+ Hub BK
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 04064888-9199-4551-997C-07326499C037
Device Start End Sectors Size Type
/dev/sda1 34 262177 262144 128M Microsoft reserved
/dev/sda2 3922778112 7814035455 3891257344 1.8T Microsoft basic data
/dev/sda3 264192 3922778111 3922513920 1.8T Linux filesystem
So no problem with GPT. It looks like your issue is at a lower level.
I had a small USB thumb drive attached at boot, than switched over to the 6TB harddrive.
Interesting you have a GPT drive working, so that rules GPT as the issue out, i guess.
I use an old WD Mybook case in which i swapped out the HDD (1TB or so) for the aforementioned 6TB, could that be the issue?
Did you format the 6TB drive after you swapped it into the My Book case and then run WD’s drive checking utility on a PC to make sure it was actually working correctly? The adapters they use in those cases are generally not as forgiving to drive swaps as a regular external drive case.
I formatted the drive while hooked on SATA in mij pc than put in the My Book case.
This morning i connected the 6TB in the My Book case to my pc, deleted the partition and try to create it again same way i did before. Now i can only allocate up to 1.45TB… So the My Book case being the flaw here seems very plausible.
I’ll order a new HDD USB case to see if that solves it.
Grahamh, do you have that 4TB HDD connected by USB to the Vero?
Yes. I used one of these for a while with a 2TB disk but then got the Seagate Backup Plus. The USB hub sockets are the USP - I plug two DVB sticks into those for live TV.
Last sunday the new HDD bracket arrived, i swopped the drive and made a new 6TB GPT ExFat partition. The Vero recognised the HDD immediately.
So, many thanks to all of your excellent support, the problem is solved. I never thought the issue would be found in the WD HDD bracket, the more because it worked just fine while attached to my pc. So some supreme detective work there.
Glad to hear that this is now solved.
I wanted to add just one more thing for completeness sake.
The HDD formatted in ExFat gave me some struggle when copying large files (win10, smb, Vero). I didn’t spend too much time figuring this out but instead reformatted the HDD to NTFS and all works like a charm now.
ExFat might not be the best option in a Windows network, idk.
In Debian Bullseye, exFAT now uses the kernel module so performance is improved significantly as it no longer goes through FUSE.
