Dtoverlay=gpio-shutdown
Hi all
I’ve successfully enabled a hardware switch on a raspberry pi 3 running standard raspbian stretch, simply by adding a switch connected to GPIO3 and ground, and adding the line “dtoverlay=gpio-shutdown” to /boot/config.txt as described here:
https://github.com/raspberrypi/firmware/blob/master/boot/overlays/README
This switch will shutdown the pi (and if already shutdown, power it up again).
Now for my questions to all you masters of OSMC:
Why does this setup not work when running standard OSMC image?
How can I get it working?
Because the gpio.shutdown overlay is not part of OSMC (see /boot/overlays)
Can try to copy it into the directory or kindly ask @sam_nazarko to include it in the next update
Is it a recently added overlay? If so, it will likely come with a new kernel update
@sam_nazarko: Oh yes please include this overlay in the next update. It’s a must! :slightly_smiling_face:
Thank you very much.
Even with the correct overlay “dtoverlay=gpio-shutdown” it still is not working. I even copied gpio-shutdown.dtbo from a working Raspbian image and that didn’t help.
Under Raspbian you’ll see:
[ 10.301261] input: soc:shutdown_button as /devices/platform/soc/soc:shutdown_button/input/input0
in dmesg. But with OSMC there is nothing - so possibly something to do with the kernel?
Probably some CONFIG_GPIO options missing.
I’m sorry to revive this old thread, but it’s what comes closest to my problem.
I have this almost working on Raspbian Stretch with Kodi 17.6 Krypton. I haven’t tried on my OSMC image yet.
I have added dtoverlay=gpio-shutdown,gpio_pin=3 to /boot/config.txt (and /boot/overlays/gpio-shutdown.dtbo is of course present).
Nothing happens when I press the button, if Kodi is running, but when I exit Kodi and use the Raspbian desktop, then pressing the button works fine.
What needs to be configured to make it work inside Kodi?
/Mogens
This seems to be very similar to this thread. In the last post I wrote:
I came across this thread on GitHub https://github.com/osmc/osmc/issues/434 where it was suggested that Kodi was (still is?) capturing the events and doing nothing with them. What’s the current state of play @sam_nazarko?
Please stop Kodi from the command line (systemctl stop mediacenter) and see if the button then works on OSMC.
