Hi All
I have a file 1080p DTS-HD MA 7.1 x264.mkv. The sound plays OK but the video is really jerky. I thought VERO 4K can handle everything and I am hoping it’s just some of my default settings on it are wrong. It’s connected via HDMI to my Pioneer amp which can handle DTS-HD and I have sound set on Vero as passthrough. However it still shows on my amp as PCM and not DTS-HD. Also while playing all processor cores on the Vero go to 98%-100% so clearly it’s struggling.
I had another file with DTS-HD MA 7.1 and it plays OK. That’s the only file which is almost unwatchable.
Also it must be something with settings but recently all files (no matter what audio TrueHD, DTS, DTS-HD they all show on amp as PCM!
Is it possible that something is wrong with Vero itself? I lost front blue led light as well recently (the one that shows the Vero is on) so maybe something is wrong.
Thanks,
-= MEDIA INFO FILE =-
General
Unique ID : 208758552487636399468967154282562259252 (0x9D0D6F4B022674CC030EBD75714F0934)
Complete name : I:\Filmy!Nowe 2018\The Greatest Showman 2017 BluRay 1080p DTS-HD MA 7.1 x264-LEGi0N\The Greatest Showman 2017 BluRay 1080p DTS-HD MA 7.1 x264-LEGi0N.mkv
Format : Matroska
Format version : Version 4
File size : 14.4 GiB
Duration : 1 h 44 min
Overall bit rate : 19.7 Mb/s
Encoded date : UTC 2018-04-10 18:44:43
Writing application : mkvmerge v22.0.0 (‘At The End Of The World’) 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : AVC
Format profile : High 10@L4.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 13.5 Mb/s
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.367
Stream size : 9.89 GiB (69%)
Writing library : x264 core 155 r2901 7d0ff22
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.90:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=22 / scenecut=40 / intra_refresh=0 / rc_lookahead=100 / rc=crf / mbtree=1 / crf=13.0 / qcomp=0.60 / qpmin=0 / qpmax=59 / qpstep=4 / vbv_maxrate=38000 / vbv_bufsize=38000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.30 / aq=1:0.90
Language : English
Default : Yes
Forced : Yes
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS ES XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 5 243 kb/s
Channel(s) : 8 channels
Channel layout : C L R Ls Rs LFE Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.84 GiB (27%)
Title : English DTS-HD MA 7.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 336 MiB (2%)
Title : English Descriptive AC3 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 224 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 168 MiB (1%)
Title : English Directors Commentary AC3 2.0
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 43 min
Bit rate : 167 kb/s
Count of elements : 5255
Stream size : 124 MiB (1%)
Title : English Sing Along Lyrics .sup
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Bit rate : 51.5 kb/s
Count of elements : 3728
Stream size : 38.1 MiB (0%)
Title : English SDH .sup
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Duration : 1 h 36 min
Bit rate : 54.2 kb/s
Count of elements : 2359
Stream size : 37.5 MiB (0%)
Title : English Directors Commentary .sup
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:1
00:03:21.618 : en:2
00:11:33.985 : en:3
00:16:21.314 : en:4
00:21:13.731 : en:5
00:25:04.169 : en:6
00:32:10.178 : en:7
00:36:09.626 : en:8
00:41:38.413 : en:9
00:44:41.053 : en:10
00:48:24.151 : en:11
00:53:11.146 : en:12
00:56:20.711 : en:13
01:01:34.816 : en:14
01:07:33.883 : en:15
01:12:00.983 : en:16
01:18:23.699 : en:17
01:22:07.131 : en:18
01:29:04.798 : en:19
01:37:09.449 : en:20
