I’ve given the user this information already. I’m not sure if he will upload logs publicly again.
From your logs:
- You have Sync Playback to Display enabled. This should be disabled.
- Your audio settings are not configured correctly.
Aside from the “Sync Playback to Display” that really should be disabled, are you using subtitles when this occurs? If so, is the stutter there if you turn the subtitles off?
