I use a Pi2 with OSMC on a lot and would love to set up a ambilight system.
The internet is flooded with info, but a lot seems to relate to raspbmc, and the rasperry pi mk1 so I’m not sure which way to turn. Also seems to be more than one option, boblight and hyperion? I like look of the hyperion remote app though
Where should I start guys? Could do with a relatively simple tutorial / solution
I haven’t tested it yet. Don’t have the LED’s to run this, just found it interesting to see, and when I read your post here, I remembered the instructable.
thanks… but you have wasted your time. I have googled it before - how do I run a .jar file? and whats the difference between the normal version and the .ssh version? Ideally I’m looking for a comprehensive tutorial on hyperion, not help using google…
