Edimax Wireless Adaptor (Realtek rtl8192)
My Edimax Wireless adaptor doesn’t work on my RBP2. It used to work a few years ago, but not sure what distro I was using then.
From what I can find in the forums, there are a few (conflicting) drivers available. According to @sam_nazarko here, it looks like the fix might be as simple as adding the USB device IDs to some list.
lsusb
Bus 001 Device 006: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
dmesg
[ 2888.269673] usb 1-1.2: USB disconnect, device number 6
[ 2891.896543] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[ 2892.028591] usb 1-1.2: New USB device found, idVendor=7392, idProduct=7811, bcdDevice= 2.00
[ 2892.028617] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2892.028629] usb 1-1.2: Product: 802.11n WLAN Adapter
[ 2892.028642] usb 1-1.2: Manufacturer: Realtek
[ 2892.028654] usb 1-1.2: SerialNumber: 00e04c000001
lsmod
Module Size Used by
8021q 32768 0
garp 20480 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
rfkill 28672 1
iptable_nat 16384 0
nf_nat_ipv4 16384 1 iptable_nat
nf_nat 36864 1 nf_nat_ipv4
nf_conntrack 143360 2 nf_nat_ipv4,nf_nat
nf_defrag_ipv6 20480 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
iptable_mangle 16384 0
iptable_filter 16384 0
snd_bcm2835 28672 0
bcm2835_codec 40960 0
videobuf2_dma_contig 20480 1 bcm2835_codec
bcm2835_v4l2 45056 0
snd_pcm 114688 1 snd_bcm2835
v4l2_mem2mem 32768 1 bcm2835_codec
bcm2835_mmal_vchiq 32768 2 bcm2835_codec,bcm2835_v4l2
snd_timer 36864 1 snd_pcm
videobuf2_v4l2 28672 3 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
videobuf2_vmalloc 16384 1 bcm2835_v4l2
videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc
snd 86016 3 snd_timer,snd_bcm2835,snd_pcm
videobuf2_common 53248 4 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
v4l2_common 16384 1 bcm2835_v4l2
bcm2835_thermal 16384 0
videodev 229376 6 bcm2835_codec,v4l2_common,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
media 36864 3 bcm2835_codec,videodev,v4l2_mem2mem
bcm2835_gpiomem 16384 0
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 20480 1 uio_pdrv_genirq
sg 32768 0
ip_tables 24576 3 iptable_mangle,iptable_filter,iptable_nat
x_tables 36864 3 iptable_mangle,ip_tables,iptable_filter
ipv6 503808 48
Support for out of tree Realtek adapters were removed some time ago. It should be reintroduced again in the near future
Thank you for the response. I’ll try again in a few weeks.
