Enabling SMB2 and SMB3 in kernel
It seems that SMB2 and SMB3 has been disabled in Raspberry Pi kernel (at least). Would it be possible to re-enable them ?
Here is what I re-enabled:
index 4f379ef…c05a086 100644
— a/package/kernel-osmc/patches/rbp2-000-add-kernel-config.patch
+++ b/package/kernel-osmc/patches/rbp2-000-add-kernel-config.patch
@@ -1,6 +1,6 @@
— /dev/null 2016-02-29 09:14:50.439999999 +0000
+++ b/.config 2016-03-01 12:19:28.490204084 +0000
-@@ -0,0 +1,4877 @@
+@@ -0,0 +1,4878 @@
+# Automatically generated file; DO NOT EDIT.
+# Linux/arm 4.4.3 Kernel Configuration
@@ -4381,8 +4381,9 @@
+# CONFIG_CIFS_ACL is not set
+CONFIG_CIFS_DEBUG=y
+# CONFIG_CIFS_DEBUG2 is not set
-+# CONFIG_CIFS_DFS_UPCALL is not set
-+# CONFIG_CIFS_SMB2 is not set
++CONFIG_CIFS_DFS_UPCALL=y
++CONFIG_CIFS_SMB2=y
++CONFIG_CIFS_SMB311=y
+# CONFIG_CIFS_FSCACHE is not set
+# CONFIG_NCP_FS is not set
+# CONFIG_CODA_FS is not set
SMB1 is disabled on my Windows Server 2012 DC and I’m not able to connect any of my cifs share without them. I recompiled the kernel with these options and I’m able to connect by adding vers=3.0 to mount command.
better off starting a pr on github
any news regarding this?
I would also like smb3 support since it gives transfer speeds equal to or even better than nfs. And it is also a lot more firewall friendly.
I would recommend building a kernel with the changes first and testing that it works well without regressions. I’d be happy to accept a pull request.
Can we have SMB3 as a possible app in the OSMC App Store?
22 posts were split to a new topic: Smb2/3
Post a new thread with a debug log and I’ll get this sorted out. Sorry for the confusion.
