When I try to start a movie by selecting through the OSMC interface OR the Yatse app, it will occasionally work, but most often it will look like it is about to start, and then simply go back to the menu.
If this is the MTU issue with Kodi SMB paths then you can either make you devices use SMBv3, switch to system paths, or just enable settings>services>SMB client>mitigate MTU issues with SMBv2
