Failed Dependencies
Hi Community,
After struggling to get my VPN to work with Vero V I have now tried adding links / add-ons.
Every single one failed to connect or when it did certain dependencies (not sure which ones) failed to install from respository.
Any insight? advice?
We need a bit more information. Perhaps the VPN isn’t working correctly.
How did you set it up?
Could it be same as this:
No, because the user installed the VPN add-on. It sounds like the VPN itself is not working.
Yeah, but I was responding specifically to this portion:
“or when it did certain dependencies”. But it may not be related, hard to say.
Which will be caused by a lack of connectivity… particularly if nothing is working at all.
