On Vero4k I cant seem to enable the SCSI Generic module:
sudo modprobe sg
FATAL: Module sg not found in directory /lib/modules/4.9.113-64-osmc
This is required to use makemkvcon for Bluray Decryption as it only appears to now work with a /dev/sgX (scsi generic) interface and will not work with only /dev/sr0
But as far as I can tell if OSMC is not compiled with SG enabled I can’t just add it back manually?
Anyone know about enabling the Scsi Generic module in Vero/OSMC?
Since we entered the Bullseye testing period I’ve made a number of kernel configuration changes. I’m currently travelling so can’t check changes trivially for a few days, but I’d advise you check out the testing thread and upgrade. If the needed module is still missing, I’m happy to get it included, and would appreciate your testing before it gets out to general release.
Ok cheers man, I’ll be happy to test it when you get a chance to add it in.
But it’s not something I’m desperate to see implemented, if a Blu-ray doesn’t work I’ll just use an actual Blu-ray player.
But it would be nice if I could just use kodi. I’m sure eventually it will properly be able to play blurays (like Kodi v69 on the Vero 8k++ holo cube or whatever).
But till then it would be nice to know that I can watch my movies within kodi.
