This is the first time I decidet to buy a smart media center. Today I got my vero 4k and i have to say im impressed. After the first boot and the updates i watched a 1080p encode from a usb hard drive and the playback was just perfect smooth as silk but when I downloaded the youtube and twitch video stream addons i found out that some videos will play back fine without issues but on some the video will be fine but the audio will stutter as if the audio is not supported
Does anyone know about this issues ? Any help is appreciated
I dont use the vero 4k at home but at the location where i use it its a pain in the ass to troubleshoot so i will bring it back home today and provide logs and hopefully fix my issues before i take it back out
Update: So I brought the vero 4k home ( because i wanted to have a pc on hand while troubleshooting my audio issues) connected it to my tv with a hdmi cable and the audio issues i was experiencing went away. The only difference between my home set-up and the location where i was testing the vero yesterday is that yesterday I had the 4k connected to a video projector via hdmi and then I pulled the audio from the projectors audio out via jack connector.
Will now go to yesterdays location again and try to connect everything again to see what happens ( since the vero was specifically bought to run there and not at my home )
I hope the issue fixes itself as it did when i brought it home
Update2:
When I connected the vero 4k to the projector again and set the system to 1080p@60fps youtube and twitch streams and videos would have completely broken sound. When i set the system settings to 1080@24fps sound would be fine but if the youtube video or stream was at 60fps the video would look slugish and slowed down.
Here is debug look i took while trying to watch a 1080p@60fps stream wile adjust refresh rate set to always and system setings set to 60fps audio was broken.
Can I type the command while using the vero i mean in the OSMC skin ? Or only remotely via ssh ? I will be able to tell you tomorrow since im home now and i left the vero at my other place. sadly i dont know the ip so i cant log in remotely.
Thanks for the instructions do i need to set up anything locally to get ssh working ? A password or so ? Also is there an app that allows you to ssh from an ipad ? Sadly i dont have a laptop or pc at my other place and since kodi needs to be running i have to check that while being there.
When i try to ssh into my vero using putty it asks for a username and password I never had to set any passwords or user accounts while setting up the vero can anyone help me figure out with wich credentials to enter ?
That was my initial issue if display is set to 60fps in system settings the whole sound is bugged even if i navigate the skin it cracks and youtube and twitch videos have also broken sound if i set display to 24 fps stuff sounds fine but 60 fps conntent looks slugish and slowed down…
I think the problem is that there are discontinuity’s in the stream.
I think I read somewhere this is a bug with inputstream and I believe that the Twitch TV add-on uses this. If this is the case then it should be resolved in the future.
