Yes – but they are probably best discussed in their thread; or things will get a bit confusing!
When there’s some improvements to test, they will be made available
Thanks Sam
Initial testing after July release: Frameskippings are gone!
Great work Sam!
Glad to hear that.
It seems I am running into the same issue with the Advanced Video Codec. Format/Info : Advanced Video Codec
Format profile : High@L5.1. I can play other 4k videos fine but this one video formatted in this format keeps buffering plays for a second or two then stops for a couple of seconds and so on. Was this fixed in the July/Aug update. I just received my Vero 4k and upgraded to the last update. Not sure if I needed to do any other configuration. Thanks for any other input on this.
The video might be out of spec.
Can you paste the MediaInfo of the file?
Thank you for the quick response. Please see below.
Overall bit rate : 95.0 Mb/s
Video
Format : AVC
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=1, N=33
Codec ID : V_MPEG4/ISO/AVC
Duration : 2 h 44 min
Bit rate : 89.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.447
Stream size : 102 GiB (94%)
Language : English
Default : Yes
Forced : No
Color range : Full
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Bit rate mode : Variable / Constant
Bit rate : 4 018 kb/s / 1 509 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Stream size : 4.62 GiB (4%)
Title : DTS HD MA 5.1
Language : English
Default : No
Forced : No
Audio #2
Format : DTS
Mode : 16
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.73 GiB (2%)
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Bit rate : 448 kb/s
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Stream size : 527 MiB (0%)
Title : AC3 6CH @ 448 Kbps
Language : English
Default : Yes
Forced : No
Are you paying the file from connected storage or a network location? Because Ethernet cannot even maintain this bitrate.
Ok, that is what I was afraid of… yes, I am playing the file from my Qnap Nas which has a gigabit port but is being bottle necked somewhere. I know the vero only supports fast Ethernet so maybe that is it?
Such high bitrates are not even necessary for 4k content. I suspect this file is nothing more than a piece of performance test media? You should not be running across such files in the wild.
102GB movie
I hope the movie is good
Try play it locally first.
You can tweak your buffer size – this has been necessary before and we’re working on improving performance for very high bitrate clips
Ok where can I do that and how much more or less should I tweak? Thanks
http://kodi.wiki/view/HOW-TO%3AModify_the_video_cache
But would not help for a file above 94Mbit average rate. For that either would need a very stable AC wifi connection or a usb gigabit connection
That will work on Ethernet; just about.
@f0o made some changes to improve performance of some high bitrate clips; but I haven’t yet revisited things.
First thing I’d do is try and play it locally and see if that improves things. If it does – we know we are headed in the right direction.
Thanks! … Ok, can anyone recommend a USB gigabyte adapter for the Vero4k or is it not worth it. I do have an AC Router that is literally right next to the Vero. Maybe I should just switch to wireless?
Try to switch to wireless. You have nothing to loose as the AC adapter already build in
If I put the movie on a USB 3 drive will that be local enough?
Switched to wireless and it was 10x worse.
You’ll have to try to know.
