Got my first Raspberry Pi yesterday, version 2 model b. The install of osmc went smooth, and the wifi dongle (tp-link) worked like a charm.
After I mounted a external hdd from a external powered usb hub and rebooted I started getting kernal panic. It did not matter if I pulled the plug to restart, still the kernal panic. So I reinstalled it again, and the same thing happened. Works like a charm until I mount the external hdd.
Then I tried xbian and open lec and the same think happened there to. After mount of external hdd the os would not start.
Then I crossed this post, Missing device node for CPU - #6 by keith217 and did a fresh install again of osmc, and before trying to mount anything I ran the following.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
After the update and upgrades where complete and the os was rebooted everything seems to work. I can mount the external hdd without any problem and I can pull out the power plug and the os still starts.
Has anyone else experienced this?
