Hi, I’m trying to get Fstab mount working but it gives me an error. I followed exactly this guide Configuring fstab based NFS share mounts
My entry in Fstab is:
192.168.0.117:/volume1/Movies /mnt/Film nfs noauto,x-systemd.automount 0 0
The error I get after “sudo mount /mnt/Film” is:
mount.nfs: requested NFS version or transport protocol is not supported
I’m trying to mount a sygnology NAS.
Trying adding nfsver=3, so:
192.168.0.117:/volume1/Movies /mnt/Film nfs nfsver=3,noauto,x-systemd.automount 0 0
Thanks Tom.
Nope, it gives me the same error.
Double check nfs is enabled on the nas and what version; its normally nfs3 and a tick box for nfs4.
Thanks Tom.
Yes, NFS is enabled I can acces it through Kodi’s normal mounting options but it is to slow for hi bitrate movies hence the Fstab mount.
On my synology I can not find the NFS version but the tick box for nfs4 was checked. Should i uncheck it or change the version in Fstab?
Thanks in advance.
Try changing nfsver=3 to nfsver=4, in the fstab entry.
Thanks Tom.
My deepest apologies, the ip adress was that of the Vero 4k not the NAS. I changed it and it is working now. my bad.
nsfver=4 gave an error though, once I removed it it worked.
I can watch 110 Mps without a problem now. very happy.
thnx.
Things like that can happen. Have a good laugh, move on and enjoy your Vero 4k!
Tom_Doyle
Split this topic
13
