Hi there!
I just updated my Raspberry Pi 2 with OSMC to the September update, which is bringing, among others, a “fix for issues with Full Frame 3D playback on Raspberry Pi”.
Full Frame 3D is something I’ve been trying to get working since I bought my Raspberry Pi 2, without success.
I’ve read other threads on the Help and Support forum, such as this one. So I do have:
- “Adjust display refresh rate” set to “Always” (switched from “On Start/Stop”, just in case)
- “Support MVC video (full frame 3D)” enabled
- “Use Full HD HDMI modes for 3D” enabled
Here is the result of “tvservice -m CEA”, even though I think it’s not used anymore:
osmc@osmc:~$ tvservice -m CEA
Group CEA has 16 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive 3D:TopBot|SbS-HH
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced 3D:FP|TopBot|SbS-HH
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
(native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive 3D:TopBot|SbS-HH
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive 3D:TopBot|SbS-HH
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced 3D:FP|TopBot|SbS-HH
mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
(prefer) mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive 3D:TopBot|SbS-HH
mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 33: 1920x1080 @ 25Hz 16:9, clock:74MHz progressive
mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive
(I own a Panasonic TX-P50ST60E)
And after launching a 3D Blu-ray MKV Remux, “tvservice -s” returns:
osmc@osmc:~$ tvservice -s
state 0x12000a [HDMI CEA (32) RGB full 16:9], 1920x1080 @ 23.98Hz, progressive
Whereas with a 3D Blu-ray Half SBS transcode, I get:
state 0x12000a [HDMI CEA (32) 3D FP RGB full 16:9], 1920x1080 @ 23.98Hz, progressive
And a really crappy image quality.
Any idea what can be wrong?
Anyway thank you for OSMC which, beside my 3D issue, is the perfect mediacenter solution.
