General
Unique ID : 50407062768579154060920408848361478439 (0x25EC0C12A47838414F7BEF0861665927)
Complete name : F:\3D SBS\MCU SBS\Ant-Man 3D.mkv
Format : Matroska
Format version : Version 4
File size : 14.9 GiB
Duration : 1 h 57 min
Overall bit rate : 18.2 Mb/s
Frame rate : 23.976 FPS
Movie name : Ant-Man / Ant-Man
Encoded date : 2022-09-28 22:14:24 UTC / 2022-09-14
Writing application : mkvmerge v70.0.0 (‘Caught A Lite Sneeze’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4 / x264_x64.exe / x264 0.164.3095 baee400 / (libswscale 5.9.100) / (libavformat 58.76.100) / (lsmash 2.16.1) / built on Jun 1 2022, gcc: 10-win32 20210110 / x264 configuration: --chroma-format=all / libx264 configuration: --chroma-format=all / x264 license: GPL version 2 or later / libswscale/libavformat license: GPL version 2 or later
Encoding settings : --crf 23 --preset medium --sar 1:1 --range tv --colormatrix bt709 --frame-packing 3
Original source form : Blu-ray 3D
Cover : Yes
Attachments : cover_land.jpg / small_cover_land.jpg / __ENCODE_3D_MOVIE.avs / __ENCODE_3D.cmd / BD3D2MK3D.log / 3D-Planes.zip
AUTHOR : BD3D2MK3D 1.25
Video
Format : AVC
Format profile : High@L5
MultiView_Count : 2
MultiView_Layout : Side by Side (left eye first)
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 10.3 Mb/s
Width : 3 840 pixels
Height : 1 080 pixels
Display aspect ratio : 3.556
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.103
Stream size : 8.41 GiB (57%)
Title : 3D Full-SBS (x264 high CRF 23 preset medium)
Writing library : x264 core 164 r3095 baee400
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=30 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / frame-packing=3 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Matrix coefficients : BT.709
Audio #1
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 4 677 kb/s
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.83 GiB (26%)
Title : English (Original DTS-HD-Master)
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.23 GiB (8%)
Title : English (Original DTS)
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround
Codec ID : A_AC3
Bit rate : 320 kb/s
Channel(s) : 2 channels
Channel layout : L R
Stream size : 268 MiB (2%)
Title : English (Original AC3 Stereo)
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Stream size : 536 MiB (4%)
Title : French (Original AC3)
Language : French
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Title : Spanish (Original AC3)
Language : Spanish
Default : No
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 56 min
Bit rate : 65.8 kb/s
Frame rate : 0.491 FPS
Count of elements : 3432
Stream size : 54.9 MiB (0%)
Title : English 3D (BD SUP)
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Bit rate : 56.5 kb/s
Frame rate : 0.434 FPS
Count of elements : 3038
Stream size : 47.1 MiB (0%)
Title : French 3D (BD SUP)
Language : French
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Bit rate : 58.7 kb/s
Frame rate : 0.438 FPS
Count of elements : 3062
Stream size : 48.9 MiB (0%)
Title : Spanish 3D (BD SUP)
Language : Spanish
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Duration : 1 h 54 min
Bit rate : 331 b/s
Frame rate : 0.002 FPS
Count of elements : 14
Stream size : 277 KiB (0%)
Language : French
Default : No
Forced : No
Text #5
Format : PGS
Muxing mode : zlib
Bit rate : 220 b/s
Frame rate : 0.001 FPS
Count of elements : 10
Stream size : 184 KiB (0%)
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : 1 - 0:00:00
00:02:08.836 : 2 - 0:02:09
00:08:40.186 : 3 - 0:08:40
00:15:24.840 : 4 - 0:15:25
00:19:59.740 : 5 - 0:20:00
00:27:50.210 : 6 - 0:27:50
00:33:07.234 : 7 - 0:33:07
00:38:53.956 : 8 - 0:38:54
00:44:36.465 : 9 - 0:44:36
00:49:22.458 : 10 - 0:49:22
00:57:44.251 : 11 - 0:57:44
01:00:48.811 : 12 - 1:00:49
01:06:31.528 : 13 - 1:06:32
01:23:21.287 : 14 - 1:23:21
01:34:20.529 : 15 - 1:34:21
01:47:34.072 : 16 - 1:47:34
