This is very odd, but I will give it a try. The remote itself hasn’t changed, why would the developers suddenly change the interpretation of the keypresses?
One other thing. When running OSMC, the remote is very unresponsive. Some keypresses are not received at all.
I just rebooted the Pi into Raspbmc and the remote is, once again, 100% responsive. Every keypress is received and logged.
There is something about OSMC that messes with this remote.
I’m wonder if I need to select a different remote in MyOSMC->Remotes?
Which one is correct for this remote?
Here’s what the Kodi log shows for the colored buttons on the remote when run under Raspbmc. All the correct codes are there:
Bleach:~ mnewman$ ssh pi@192.168.0.151
Warning: Permanently added '192.168.0.151' (RSA) to the list of known hosts.
pi@192.168.0.151's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
pi@raspbmc:~$ tail -F /home/pi/.kodi/temp/kodi.log | grep OnKey
10:45:52 T:3037933568 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
10:45:52 T:3037933568 DEBUG: OnKey: ctrl-alt-leftalt (0x5f0d4) pressed, action is
10:45:52 T:3037933568 DEBUG: OnKey: ctrl-alt-164 (0x5f0a4) pressed, action is
10:45:52 T:3037933568 DEBUG: OnKey: ctrl-alt-one (0x5f031) pressed, action is Info
10:45:53 T:3037933568 DEBUG: OnKey: ctrl-alt-f1 (0x5f090) pressed, action is
10:45:53 T:3037933568 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
10:45:53 T:3037933568 DEBUG: OnKey: ctrl-alt-leftalt (0x5f0d4) pressed, action is
10:45:53 T:3037933568 DEBUG: OnKey: ctrl-alt-b (0x5f042) pressed, action is
10:45:53 T:3037933568 DEBUG: OnKey: ctrl-alt-two (0x5f032) pressed, action is OSD
10:45:53 T:3037933568 DEBUG: OnKey: ctrl-alt-f2 (0x5f091) pressed, action is
10:45:54 T:3037933568 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
10:45:54 T:3037933568 DEBUG: OnKey: ctrl-alt-leftalt (0x5f0d4) pressed, action is
10:45:54 T:3037933568 DEBUG: OnKey: ctrl-alt-c (0x5f043) pressed, action is
10:45:54 T:3037933568 DEBUG: OnKey: ctrl-alt-three (0x5f033) pressed, action is ContextMenu
10:45:54 T:3037933568 DEBUG: OnKey: ctrl-alt-f3 (0x5f092) pressed, action is
10:45:55 T:3037933568 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
10:45:55 T:3037933568 DEBUG: OnKey: ctrl-alt-leftalt (0x5f0d4) pressed, action is
10:45:55 T:3037933568 DEBUG: OnKey: ctrl-alt-164 (0x5f0a4) pressed, action is
10:45:55 T:3037933568 DEBUG: OnKey: ctrl-alt-four (0x5f034) pressed, action is Delete
10:45:55 T:3037933568 DEBUG: OnKey: ctrl-alt-f4 (0x5f093) pressed, action is
