[quote=“the_bo, post:1, topic:12758”]
On linuxtv it shows device supported Geniattech HDStar linuxtv.
[/quote]but on other project there is info that support is broken?
Do you have a link where says its broken thanks. I think drivers are still up to date on openelec not sure. I copied over the firmware to lib/firmware on osmc. It seems its a hardware fault. I’ll keep testing.
Although LinuxTV.org shows that this is a compatible tuner, the device does not have mainline kernel support. Although it is possible to apply a kernel patch in order to use TVheadend or VDR, we do not provide any support for this use case.
11.902508] ts2020 4-0060: Montage Technology TS2022 successfully identified
[ 11.902570] usb 1-1.3: DVB: registering adapter 0 frontend 0 (Montage Technology M88DS3103)…
[ 12.518168] Registered IR keymap rc-su3000
[ 12.518478] input: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/rc/rc0/input2
[ 12.519677] rc rc0: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/rc/rc0
[ 12.519692] dvb-usb: schedule remote query interval to 150 msecs.
[ 12.519702] dw2102: su3000_power_ctrl: 0, initialized 1
[ 12.519707] dvb-usb: SU3000HD DVB-S USB2.0 successfully initialized and connected.
[ 12.519820] usbcore: registered new interface driver dw2102
m88ds3103 3-0068: found a ‘Montage Technology M88DS3103’ in cold state
[ 23.598008] m88ds3103 3-0068: downloading firmware from file ‘dvb-demod-m88ds3103.fw’
[ 24.640379] m88ds3103 3-0068: found a ‘Montage Technology M88DS3103’ in warm state
[ 24.640389] m88ds3103 3-0068: firmware version: 3.B
[ 24.656308] usb 1-1.3: DVB: adapter 0 frontend 0 frequency 0 out of range (950000…2150000)
If it can be applied to 4.4 that would be good.
We are moving to 4.9 but I won’t employ the media_build approach you originally linked to. It’s a maintenance nightmare and only makes sense on older kernels
We are happy to carry downstream patches for DVB however. When 4.9 is released, ping me and I’ll take a look at what changes are necessary to get this supported in OSMC
Any chance of providing me with a test build with this patch applied?
I will be able to test my current working tevii s660 to ensure it still works fine with this patch as it uses the same dw2102.c file also.
Be nice to have this v3 device working as i want to test it to see if it produces the same green artifacts that i’m getting with my current s660 device.
I’m not familiar with creating a PR on github but here are a few links to the patch.
