When I plug my Raspberry Pi into my monitor everything works fine and I can see OSMC load up but when I use my old TV I see the logo appear then my screen starts to flash green.
My old TV displays in 1080i and there is no way to change it.
While looking for my problem I found this forum: Blank green screen on HDMI that says to change videoscreen.screenmode but the option doesn’t exist in my Guisettings.xml.
Thanks for the help ~
reproduce the issue
When I select to upload it says unable to retrieve URL…
